fastset/easiest way to cut 1/8" x 3/4" angle CRS?
Results 1 to 20 of 20
    Nov 2007
    ohio
    621
    32
    17
    Default fastset/easiest way to cut 1/8" x 3/4" angle CRS?
    The cut isn't a precision cut and has a 1/8" of flexibility. I am currently using a horizontal bandsaw, but it is taking more time than I would like for cutting and positioning. I want to say the metal yard I buy stuff from has a "nibbler", but am not sure that is the correct term since I am not finding many results when I search HGR (nearest place to buy used).
    Any other options, or idea what other terms to search under?
    Chris
  2. Likes Whysosharp liked this post
  3. #2
    Feb 2014
    Cartersville, Ga
    76
    7
    43
    "Angle Shear" is the term you are using. 3/4x1/8" angle is no problemo.
    Roper Whitney #4 would be a good choice.
  4. Likes Caspian, Mike C. liked this post
  5. #3
    Apr 2009
    NC, USA
    39
    8
    18
    At the fab shop I worked at we used a metal devil type circular saw for cutting all our carbon steel lengths. Super fast and leaves clean cuts.
  6. #4
    Oct 2012
    Albany Ny USA
    323
    1065
    163
    Ironworker or piranha but those are big beastly machines.
    Really awesome and super useful though.
  7. #5
    Apr 2005
    Brandon, MS
    775
    107
    140
    3/4" angle with an 1/8" wall?
    Ironworker w/ angle shear: 1 second
    Metal Circular Saw: 3 seconds
    Bandsaw: 5 seconds
    The value added portion of the job doesn't seem to take much time. Perhaps you should put a little effort into your setup and that would be a more efficient savings. How are you cutting the angle? Are you cutting it like an "L" or a "<" ?
  8. Likes Caspian liked this post
  9. #6
    Nov 2007
    ohio
    621
    32
    17
    Quote Originally Posted by CatMan View Post
    Bandsaw: 5 seconds
    good question. In hindsight, I may stick with the bandsaw. I am using my bandsaw to do the prototype. However, if made in volume, I can stack the angle and cut 20 at a time. Naturally, time wouldn't be as fast as the Ironworker, but it will give me time to find a used ironworker for the right price.
    I was cutting them like this ^ for my prototype, but in bulk, they would be >
  10. #7
    May 2011
    New Jersey
    429
    8
    138
    You could triple stack cut them in a chop saw or 1000 stack in band saw if you know how to properly do that. For one and twos I just use the cut off wheel. You also have to think about clean up of the end. Ironworkers sounds great but it could leave a hell of a burr depending on adjustment. Chop saw will leave a nice burr, a steel chop saw or bandsaw will leave minimal clean up.
    Sent from my 2PS64 using Tapatalk
  11. #8
    Apr 2009
    NC, USA
    39
    8
    18
    Ironworkers are great tools but I don't know any with a 1 second cycle time and from my experience it was clunky to line up your mark for shearing and almost impossible to get a straight cut because of how it torqued the piece while cutting (maybe ours was just too old and loose). It can also deform the ends a good bit. The circular saw is just as fast as cutting through a 2x4 and it's easy enough to square up and get a nice straight cut with minimal burr, setting up for angled cuts is simple as well. Stacking pieces in a bandsaw can be fast too but if something moves or isn't lined up right for whatever reason, you just cut X number of pieces to the wrong length.
  12. #9
    Nov 2007
    ohio
    621
    32
    17
    I agree about the circular saw with respect to being easy, but would liken it to an abrasive saw where there would be a mess in the shop when running it for production.
    I think stacking in a bandsaw would be easiest. I could triple up and do 30 at a time, easy and having cut stacked, have never had a problem with alignment.
    I still like the idea of the ironworker if I could set up a stop and measure them off quickly. Never thought about torquing. I have never used one. I will look more into that before buying.
    Thanks for the input/ideas
    Chris
  13. #10
    Aug 2011
    new plymouth id
    262
    22
    69
    did some of that with stacks of 2" angle would just run a bead of weld up the butt ends so nothing could move had to throw away the butt though
  14. #11
    Oct 2009
    Portland, Oregon
    3,577
    3830
    1757
    I haven't found much I can't cut reasonably quick in a good bandsaw.
    If you have a decent 1" blade or bigger saw it should cut through a healthy stack of thin angle real quick.
  15. #12
    Jul 2013
    California, USA
    518
    577
    568
  16. #13
    May 2006
    Seattle
    1,551
    26
    270
    Just want to point out for a one off a hacksaw and a vise will do this job toot sweet with very little setup time if you don't have to look for your hacksaw.
    metalmagpie
  17. #14
    Nov 2004
    Birmingham, AL
    13,031
    6127
    2421
    Another vote for a R/W manual angle shear. Fast as you can load it in there and push the handle down. Fraction the cost of an ironworker, unless you can justify the ironworker for other jobs.
  18. #15
    Oct 2017
    49
    14
    24
    Bandsaw: 5 seconds
    In my experience of all of the cutting methods you listed bandsaws are the easiest to setup so that they take forever to get through anything. It seems to me like this is a case of misusing the bandsaw, or maybe there are many different lengths that need to be cut.
  19. #16
    Oct 2012
    Albany Ny USA
    323
    1065
    163
    Iron workers are great for larger runs of rough work... 10-20 min to set up, hours of chomping. If your cutting up 10 or less lengths of material, go for a band saw (welded stacks).
    You want to turn 100+ lengths of angle into smaller bits of angle (and can deal with a slightly chewed up end) go for a ironworker.
  20. #17
    Oct 2017
    49
    14
    24
    Quote Originally Posted by PlasmaOnTheBrain View Post
    I disagree. It seems to me it's always faster to use the ironworker. In one setup you have to measure, clamp, and wait for the saw (even if short), while otherwise you just mark your angle, feed it in, and chomp it off.
    If we are talking in terms of ROI then I agree an ironworker is overkill for short runs.
  21. #18
    Sep 2005
    Connecticut
    4,239
    485
    520
    If the bandsaw is taking longer than you would like, maybe it's time for a bigger bandsaw?
    I always like excuses to buy a better tool.
    Steve
  22. #19
    Dec 2004
    uk
    12,476
    3491
    5598
    Quote Originally Posted by Caspian View Post
    NO in bulk they would be like, >>>>>>>>>> :-)
  23. #20
    Jul 2004
    Asheville NC USA
    8,949
    3405
    2981
    I've got a Whitney 3 x 1/4 hydraulic angle shear and notcher. The shear is double cut so it doesn't mangle the end of the angle. I wouldn't even consider using it to cut 1/8 x 3/4 angle, regardless of quantity. I'd cut it in a band saw. If there's much quantity, then stack it and run a weld across the back end.
    The shear/notcher is handy when building a frame or similar work where you cut a couple pieces, measure, cut another one, etc. The notcher allows for coped corners which are far quicker and cleaner than mitered ones. But for any sort of production cutting on small angle its far easier and faster to get accurate clean cuts via sawing.
