brianweldor
Cast Iron
- Nov 1, 2007
- WV
I make a lot of aluminum post caps that fit over square wooden posts. They typically fit a 6" or 8" square post, and are made up from 4 separate parts, one for each side. Right now I just clamp to a simple square fixture, tack up (Tig), and then struggle like hell to get the weldment off of the fixture because the shrinkage from the tacks sucks it tight to the fixture.
I'd like some kind of collapsible fixture that would hold my dimension for clamping and tacking, but then get out of the way so I can easily remove the weldment. Any ideas? I was thinking some kind of central cam that would press outward against the parts, but could then rotate and release the pressure for removal. The travel shouldn't need to be more than .030" or so.
