Doyle4281
- Aug 15, 2012
- United States
Hello all, I need some advise on some modifications I need to do on a factory Nissan fuel rail. I need to attach a -8 make jic fitting to one end, as well as attach an 1/8 npt female boss to the end of a tube. Being that there are existing brazed joints very close to the area being modified, what method should I use. I don’t want to damage the existing brazed joints. I know a talented TIG welder, however we haven’t tried this type of modification before. I thought about sending it to someone to be silver soldered or brazed, but I am unfamiliar with process and it’s strength capability. The rail is for a fuel injectors turbocharged vehicle, so will see upwards of 80 psi fuel pressure. I would post pictures if I knew how. Thanks
