Grinding a point on 5/8" hot roll rod. - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41
    Feb 2014
    Minnesota
    124
    10
    28
    Might not need anything to spin the rod in all reality, as the grinder will probably spin it just fine itself. Just need some in-feed pressure and a light grip to keep the rod from spinning too fast.
  2. #42
    Jan 2015
    Michigan
    310
    146
    Tony Quiring, I appreciate your concern about the plates, soil, rusting etc.
    Please remember, I'm a welding shop, I make things all the time that get drawn on little more than a napkin, I do understand that steel rods should be coated, I know that new rods in bridges tend to be epoxy coated, I also know that a rod should be kept at least 2" from the exterior surface of the concrete, I understand that electrolysis will cause the rod to corrode up inside the concrete, when it expands it will swell to about 3 times its original diameter causing the concrete to spall which in turn cracks the concrete.
    Thank you for your concern, I will make sure to let my customer know that he should have the rods epoxy coated, unfortunately, I doubt they will.
  3. Likes digger doug, roysol liked this post
  4. #43
    Jan 2015
    Michigan
    310
    146
    I appreciate every ones input, I have passed the buck on this one, thanks Snowman, I pawned the job off on the local blacksmith Ron Bishop who has a forge and power hammers, I will cut them and do all the fab work, he will put the point on them.
  5. Likes Monarchist, roysol liked this post
  6. #44
    Oct 2012
    Virginia
    9,181
    4965
    4073
    Quote Originally Posted by Portable Welder View Post
    Good on Yah! And a "thank you" on behalf of the poor lathe that doesn't have to deal with the grinding effluvia...
  7. #45
    Jul 2004
    Southeast Michigan
    6,287
    220
    1314
    Quote Originally Posted by Tony Quiring View Post
    That could be issue as the rod is in contact with soil and will allow rust to start.
    Supports for rebar are chunks of concrete with wire in it so only concrete touches dirt.
    Be sure you have copy of building engineer drawing showing this.
    The GC doing the job may be coming up with their way of doing things
    If not in the approved drawing and a failure down the road caused by defect it could be issue.
    This is not an ornament but rather structural for a chemical plant so CYA is highly suggested.
    Drawing may require specific material if in direct contact with dirt.
    Usually requires a footing hole with supports cast in but bot contacting dirt.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
    Portable's description of the work is standard practice around here for structural work. I have seen engineer stamped plans out of a majority of the big players, and steel that is fully encapsulated in epoxy or even hot zinc dipped is really quite uncommon.
    Best practice and common practice are two very different things, especially in Michigan. We build for the next quarters profit, not for the 100 year (or even 30 year) corrosion concerns.
  8. #46
    Sep 2012
    California, Ventura county
    1,380
    178
    517
    subbed out sounds like the real winner.
    no pain in your butt that way.
