I'm trying to do this one the lathe, but no matter how I grind the tool , Carbide or HSS, I cannot get a good clean cut, at any RPM. Any alternatives to traditional machining you guys can suggest?
Material is steel, probably music wire .028" dia., (pretty hard but machineable) that has a black oxide coating. I need uniform grooves, depth not important .002 or .003" is fine, just enough to get thru the coating and create crisp line.
spacing every .5mm (.02") over a distance of 1.2 inches .
