43monarch
- Sep 1, 2008
- pacific northwest
First time posting on this board.Any ideas will be very much appreciated.Bought this Lincoln 300/300 about ten years ago.It stick welds like a champ with no issues but the tig function has been a real pain in the butt since I got it.Bought a new foot pedal torch,etc to get a good start and it initially welded aluminium castings I work on occationally.Problem is its unreliable.I was going to try welding a stainless steel manifold .Set my machine settings to DC-,soft start off,spark sw/start only.30 on argon also set the sets of contact points to .010.Result was a very weak fingery spark that wouldn't weld.This machine does a lot of sitting but is clean and in a dry shop that is heated a lot of the time.I am an amateur welder at best so be gentle.
