dazz
Stainless
- Aug 20, 2006
- New Zealand
What's a good simple neat method of connecting a 25mm tube to an 8mm plate steel. The application is to make a lever. The plate will end up about 30mm wide. The finished item will have torque applied, but won't be compressed or put under tension. This is a one off.
I have a stick welder and a lathe.
Ideas please.
Ideas please.
