Juanhanded
- Mar 2, 2017
I have been using a custom proprietary hand tool for work that is most similar to a shovel in that it experiences quite a bit of abrasion,it meets up with some steel objects now and then and also does some prying and experiences occasional impact,though not on any level of a breaker or jackhammer.The tool is now made of 6061 aluminum,but is ready to receive a re-design in which the business end will have a steel wear plate and chisel-style end.
My steel needs to be formable in a brake,easily weldable (TIG,is fine),take a good impact,and hold up to a good amount of abrasion.Post fabrication hardening suggestions needed as well.
Weight is a huge consideration,as this is a hand tool,ergonomics are everything and ounces matter.My instincts tell me that the wear plate area of the tool would be fine with .075 or .090 plate thickness and the chisel-like end,about .190.The outer perimeter of this plate will be bent over about an inch to give it some structural integrity,allowing other parts of the tool to be lightened or eliminated altogether.
The tool worked fine made completely out of 6061,but would need a lot of attention as far as repair and fish-plating worn out surfaces,just to give you an idea that it works hard,but is not under what I would consider to be severe duty.We are talking about 100 square inches here,and if I fabricate one,I might as well make three.Tool is used outdoors,gets wet at times and is not pampered,a stainless would also be considered.
Suggestions appreciated.
