Aaronwelder
- Oct 13, 2013
- Ashern Manitoba
Hi everyone I am on that quest to build a hydraulic system for a machine that is similar to a hydraulic ironworker. It's going to be a simple tandem Center system with one 12 volt solenoid spool so oil will be continuously be sent through the system by a fixed displacement gear pump. When the system is initiated the the spool is energized and the double acting cylinder extends and does the work. The spool is brought to neutral and the cylinder self retracts. I could run a simple single acting cylinder with a huge spring to retract the cylinder however I don’t like the idea that the rod seals would not be lubricated plus having the spring as a possible item to break is not a smart idea. I know about hydraulic kick out valves that are used in log splitters but was not planning to use them in the design. I have used ironworkers in the past but don't own one. Anyone knows how they work ? What kind of valves or spool used? I tried to look online for owner manuals for various brands of ironworkers but no luck. Thanks in advance.
