Laser cut 3/8 aluminum?
Results 1 to 8 of 8
    Jan 2005
    Houston
    5,093
    320
    1997
    Default Laser cut 3/8 aluminum?
    I know this question is 'it depends' but the shop I use for laser cutting is closed until Monday.
    They have a large CNC guided laser cutter. I think it is a Strippit.
    Is it reasonable that they could cut 3/8 aluminum plate? Or is that too thick for most tables?
    Jan 2010
    FL,USA
    673
    54
    49
    Quote Originally Posted by GregSY View Post
    I don't think you can laser cut aluminum...?? I heard it from somewhere.
    Jan 2005
    Houston
    5,093
    320
    1997
    They've laser cut 1/8" for me before with no issues. I just don't know if that translates to 3/8" or not.
    Oct 2009
    Louisville, KY, USA
    721
    198
    125
    For what it's worth, I've had 1/4" aluminum laser cut. So now we've closed half the distance between 1/8" and 3/8".
    Jul 2007
    Hampton, Virginia
    2,465
    187
    180
    I just received some 3/8" 6061 in from our vendor. His contact information is below so give him a call and ask the question.
    Walter A.
    Cleon Martin
    Laserfab, Inc.
    [email protected]
    phone: 717-272-0060
    fax: 717-272-0052
    Jan 2011
    Indiana USA
    108
    42
    It would take a high wattage laser for aluminum that thick. I run an older 3000 watt Mitsubishi and 7 gauge aluminum is about our max. Half inch regular steel is no problem though.
    Oct 2004
    Illinois
    940
    149
    114
    Usually a laser cuts have the thickness of steel in al. The problem with aluminum is that in the molten state it has near 100% reflectivity which can cause the beam to feedback to the resonator and damage it. This problem is solved with a back reflector filter. When the beam feeds back it is out of phase with the outgoing beam so this reflector is polarized to filter feedback phasing of the beam.
    For example W. A. Whitney's PlateLASER had a 6KW resenator and could cut 1.25" steel, 1.25" stainless steel and 0.5" Aluminum.
    John
    Apr 2007
    Qc, Canada
    126
    7
    I recently had 5052 h32 3/8 laser cut without problems. Cut quality was good.
    Do you have to weld the edge ? Sometime you need to grind the white on the cut edge, depend on the welding application.
    Francis
