Laser cutting Delrin?
Results 1 to 11 of 11
    Jan 2009
    "Stuck in Lodi", Ca
    3,007
    1754
    1538
    Default Laser cutting Delrin?
    Anyone ever cut Delrin (Acetal) sheets (.01" thick)? I have an inquiry to do some special gaskets but my laser is in the middle of me installing a new cooling system so I can’t even do a test run. I know it will cut OK, I don't recall things like edge finish and detail of small features or how color effects the cut.
    I could do them on the mill with a plate fixture but the laser would be so much faster and the mill would be a much higher bid cost with all the detail on these parts. The laser will be up and running in plenty of time before the parts were due.
    Trying to estimated things out here before sending in bid.
    Jan 2009
    "Stuck in Lodi", Ca
    3,007
    1754
    1538
    OK...this went well...
    I should have added these gaskets have some features that are .030 walls that's a 3 to 1 aspect ratio and the tolerance is minus .005 plus .01 thou....
    I don't recall how it melts then re solidifies on the edge.
    Jan 2011
    Indiana USA
    107
    41
    No experience with Delrin but we do tons of HDPE, neoprene and fiber gaskets with our laser. At .010 thick there should be no real issues with melting if you keep your power just high enough to cut through and move fast. I would be more concerned about material this thin moving around from the assist gas pressure. May have to tack glue it to a backer for rigidity.
  4. Likes scadvice liked this post
    Jul 2006
    Hillsboro, New Hampshire
    3,766
    762
    2475
    Sep 2010
    Vancouver Canada
    589
    380
    180
    I've cut 1/8" Delrin on a 60W VersaLaser with good results. Not as clean as acrylic but I think with a .015" overall tolerance you'll be fine.
    Jan 2009
    "Stuck in Lodi", Ca
    3,007
    1754
    1538
    Thanks all...I bid on it using the laser. Sometimes you just gotta take the chance that things will well.
    Sep 2005
    Oakland, CA
    1,868
    52
    414
    DO NOT get near the fumes- you will b a very unhappy person if you do.
  9. #8
    Aug 2010
    Minnesota
    1,314
    127
    989
    I don't actually know what is in the fumes when you melt Delrin, but one time I tacked a suspension braket that had a delrin bushing installed and the fumes knocked me on my ass. I had to go sit outside for a while.
  10. #9
    Jan 2009
    "Stuck in Lodi", Ca
    3,007
    1754
    1538
    The Laser is well vented to the outside. Thank's
  11. #10
    Mar 2005
    Kansas
    6,420
    322
    2579
    Quote Originally Posted by kustomizingkid View Post
    Probably formaldehyde.
  12. #11
    Nov 2015
    155
    9
    25
    Quote Originally Posted by scadvice View Post
    I'm sure the EPA will like that. We stopped cutting plastics with the laser for this and the machine itself. The residue from cutting plastics on laser causes all kinds of issues with the laser itself. It gets into all kinds of cracks and crevices and depending how much plastic cutting you do, can lead to some expensive maint.
