Is this a laser job?
Results 1 to 9 of 9
    Aug 2006
    greensboro,northcarolina
    2,129
    107
    397
    Default Is this a laser job?
    Need to make some small filter plates. .012 thick stainless, .250 diameter with 25 holes .012 diameter in the center inside a .158 diameter circle. Quoting 50 and 250 pieces. I can make a simple die and punch out the blanks , make a holding fixture and drill the holes, but was wondering about doing these with a laser? Tiny part I know, but maybe there is a trick I don't know about. We don't do any sheet metal fab work, just chip making.
    Jun 2002
    CANADA
    British Columbia
    2,166
    1458
    Hi RJT:
    Yes it could be but the aspect ratio of the holes may not work well for you if the holes need to be "good" holes for any reason.
    Have you considered stacking them, hole popping them and wiring the outside to size?
    Have you considered having them etched?
    Cheers
    Marcus
    www.vancouverwireedm.com
    Aug 2006
    2,129
    107
    397
    Yes, considered hole popping, but we only have a manual hole popper. One stack of 50 wouldn't be bad but would need 5 or so repeats at 25 holes per part for 250 pcs. Could be done, but i know a laser's speed would knock these out in a hurry. Didn't think of etching, I'll look into that too.
    Mar 2017
    Minnesota
    61
    28
    60
    Quote Originally Posted by RJT View Post
    We do parts like this in our Lasers. The .012 hole might not be perfect considering the beam is .008.
    We did a job a few years back where they wanted a 7/16 square with a .017 dia on .023 centers perf made from .006 Stainless Fullhard Shim Stock. We did it...
    Jun 2015
    CANADA
    British Columbia
    1,046
    241
    547
    I was making similar items using resist and etching. Photo resit will produce excellent results, but even laser printed resit cam do the job. The process is actually quite fast and you can squeeze all your patterns on one or two sheets of the metal foil.
    Aug 2006
    2,129
    107
    397
    4 FN 27
    i sent you a PM.
    Jul 2006
    Wisconsin
    1,261
    218
    883
    Quote Originally Posted by 4 FN 27 View Post
    Just curious, didnt I read that the new fiber lasers have a beam width of like .003"
    Mar 2017
    Minnesota
    61
    28
    60
    Quote Originally Posted by JP Machining View Post
    Our Fiber Lasers are geared to production. This type of part we run on an old Amada 1212 Pulsar C02. My operator is the one who is capable...not the machine...he makes it work. He has been running Lasers since 1977.
    Our Fibers typically run about .0015-.0018 Cutter Comp so yes you are correct...about .003.
  9. Likes alexhawker liked this post
  10. #9
    Apr 2009
    Ohio
    168
    16
    53
