FMKWELDING
- Jul 7, 2017
So I built my own machine. This is my second and I thought I had the bugs worked out from the first one. Well that's a big no. Anyway the trouble I am encountering is the feed screw set up. I have a Bridgeport type servo feed connected via a love joy coupling. Goes through a bearing which is set screwed to the all thread so that it can push and pull drill motor. Now the issue is the all thread which is 5/8-18 I think B7 is stripping. I had this issue before buthe this time I used a tacked nut on both side of the plate. Today it stripped to the point that it stopped the servo and stripped a gear in it. I need something that can handle repeated trips back and forth and typically within the same 3 to 4 inches all the time. I am open to any suggestions you may have. I used 5/8-18 because I felt it needed to be that slow of a pitch because I am already at about slow as the servo feed will go? Will have pictures asap
