Miller syncrowave 250 power source question
Results 1 to 9 of 9
    Sep 2012
    California, Ventura county
    1,380
    178
    517
    Default Miller syncrowave 250 power source question
    Miller Syncrowave 250 will all of them run on
    single phase or is there a year when they started
    being able to work off just about any standard US electric line
    power both 3 or single phase?
    found one close to home at a good price, but it's from an industrial
    setting, so if it needs 3 phase it's of no use to me.
    Aug 2010
    Minnesota
    1,362
    128
    1033
    I have never seen a three phase Syncrowave 250, not saying it doesn't exist but all the ones I have seen have been single phase with taps internally to run 208, 240 or 460 power.
    Sep 2012
    1,380
    178
    517
    ok so the guys with 3 phase power just use 2 legs or what ever?
    May 2009
    San Jose, CA
    163
    129
    165
    I was helping a car restoration shop get a Synchrowave welder up and they were convinced that it was 3 phase. I spent some time on the phone with Miller tech support, and they were emphatic that it was a single phase machine. I downloaded the manual for the shop, and it clearly stated this also. They hooked it up to single phase 240 volts and it works fine. If you do download the manual from Miller's site, you can check this yourself.
    Regards,
    Michael
    Oct 2012
    Marion, Iowa
    271
    125
    68
    The Owners manual only indicates single phase.
    I have one, purchased new, and ordered the power factor kit, which is a bank of capacitors. This lowers the operating current. My shop is on a 60 amp service, and over 120 feet of branch wiring (6AWG copper). I've never tripped the circuit breaker on the main panel.
    Mar 2009
    3,694
    72
    595
    Quote Originally Posted by ignator View Post
    Looking at manual OM-363 page 13. There are three tables which follow the same trend regarding PFC. Example from the first table (200A output 60% duty cycle):
    230VAC operation with no PFC
    Input current = 77A
    Idle current = 2.8A
    230VAC operation with PFC
    Input current = 52A
    Idle current = 49.5A
    If the welder is in idle with PFC the input current is high. It indicates that if you are TIG welding, which is a slow process, the idle time is expensive. As it was explained to me, unless you are welding all day the PFC capacitors are not saving you electricity (according to the print). As it is the PFC kit is a bank of two capacitors. If the amperage they state in the manual is not REAL current then I would like to know about it.
    The back panel has a chart for jumping single phase input voltages:
    200V
    230V
    460V
    Oct 2012
    Marion, Iowa
    271
    125
    68
    I understand that the capacitors are across the AC line once the welders power switch is turned on. My point was that for marginal electric service, the PFC capacitors prevented my main circuit breaker from tripping.
    Also note that the idle current is one heck of an apparent (leading reactive) power, most of which the power meter does not measure, unless it's balancing a very large inductive power (which is what the power company wants).
    Aug 2010
    Minnesota
    1,362
    128
    1033
    Mine is wired solid to a 100 amp breaker on 240 single... nice being able to hold it wfo at 310 amps sometimes
    Mar 2009
    3,694
    72
    595
    You are correct about the line.
    I remember that a welding acquaintance and the Miller website or someone in Miller service had warned me off about the PFC capacitors.
    I'm going to look at it again. Thanks for the message.
