Spud
- Jan 12, 2006
- Brookfield, Wisconsin
Aluminium: window frames,door frames and shower doors/cubicles.
Need a fastening method that will allow frames pieces to be removed should the glass contained within the frame break.
_
Some of these doors/windows will be in the bathroom, so they will see a lot of water.
So I assume I can not use stainless steel screws, as that would lead to galvanic corrosion?
Does not need to be unpainted Aluminium, powercoated Al is fine.
_
So what type of screw can I use . Will need them to be countersunk flat head screws so they do not project above surface of aluminium. Will screws suffice or do I need a nut also?
_
How do Aluminium shower door manufactuers fasten the individual frame pieces?
_
_
_
