I have an aluminum part that I need to drill out to install an EZ-Lok insert. It's an M6x1 insert, which requires a 3/8"-16 thread to install. That needs a size Q bit (.332"), but it's going into a boss sticking out from the main body of the casting that's only got an OD of .480". If I can get it centered in a 4-jaw chuck on the lathe, should I be OK to do that, or is the wall thickness going to be a problem? There's already a "pilot hole", it's the original hole with trashed M6x1 threads.
Also, if I did the math right, it looks like the recommended RPM for drilling aluminum is 3600+, does that sound right? I don't think my lathe will even do that, so I'll just have to set it on the highest gearing and let it go.
Note: I'm pretty much either going with this method (preferred) or filling it with epoxy and drilling and tapping. Those are about the only available options, for reasons that are too long to go into right now. Welding, etc., are not options. Other types of inserts (Helicoil, Timeserts) do use smaller drills, but for the cost of a full kit to install one of those I could buy a whole replacement part.
