HelicalCut
Stainless
- Apr 9, 2007
- Melbourne Australia
I recently started using a plasma cutter for demolition work and started getting ragged cuts compared to using the standard 18" long oxy cutting torch. I get much straighter and smoother cuts with long oxy torches than with short ones as I can swing the torch in an arc and roll the handle over the edge of my other hand thereby moving the fulcrum to make the arc into a straight line. Anyway it works well for me the end result being very fast straight oxy cuts, I use machine tips for manual oxy cutting as this technique enables me to keep up with them.
The problem with the plasma is the short 6" torch, not only does it give ragged cuts it greatly reduced my ability to reach into places, does anybody know of an extended body plasma torch, the machine is hypertherm 38 (slow compared to the oxy but great for non ferrous).
