The stud thing pictured alone is about an inch long and I think 4 mm dia. Each drawer has one diameter and usually a few different lengths. Head is roughly flat, no provision for driving it, and other end is precisely machined flat save a tiny, sharp teat on the axis. Cart is s/s except the plastic drawers. I'm pretty sure this was a welding setup of some kind but got no info when I acquired it. There's a box with a 110 v. Receptacles but a quick check failed to locate an electrical input to the box. Must be a buck xformer. Can you tell me what these assorted studs were being used for, if this is a common type setup in a certain industry?
