One portable welder-Two stingers?????
Results 1 to 7 of 7
    Apr 2004
    Riverdale, Nebraska, USA
    768
    94
    40
    Default One portable welder-Two stingers?????
    A friend is looking at a feedlot pen construction job. Basically would involve slapping gates, hinges, structural pipe, etc. together. I may rent him a service truck/welder(225 Bobcat) to do the job and possibly a second welder.(Miller Big 40)
    This brought to mind a question. Would the Miller Big 40 allow two guys to weld at the same time? 1/8" 6011 @ 100 amps is how I would run the job.
    I am guessing this type of thing is done on big jobs, just curious how, and too cautious/lazy to hook up a second stinger and actually try it.
    Scott
    Jun 2006
    Beaverton, OR
    5,459
    51
    No, you cant run two stingers off one machine natively. You can control the current individually. They do make du-op machines that will run two stingers. There are also external current control boxes that will limit current to each stinger.
    I went to do a service call on one site where they had two 600 or 1000 amp lincolns stacked on each other and then fed into a 8 bank duop setup which everyone ran off of.
    Apr 2004
    768
    94
    40
    OK, that makes sense.
    If you magically found a pair of the external controls how would you set the dials? 100 amps on each external control and 200amps on the welder?
    Scott
    Jun 2006
    Beaverton, OR
    5,459
    51
    You set the welder to max output. Each box has two sets of controls, one for each stinger.
    Nov 2008
    BC, Canada
    79
    13
    10
    Quote Originally Posted by svs View Post
    Scott
    Miller and lincoln make stinger banks. The biggest one I've seen ran 6 at a time. way past what you are asking, in the end unless you are doing long production / fixed jobs you may want to just use two welders.
    The problems just start with the hot start. If one guy is welding the basic machine has no way to know that the voltage needs to be higher to start the second rod off. When a welder is at rest the voltage is higher then when you are welding, it helps get started and when it drops it also helps stabilize the arc.
    good luck!
    Apr 2004
    768
    94
    40
    Thanks guys. Very clear now. I'll poke around and look for a stinger bank.
    Don't know that the friend will actually get the job, or that I'll rent the junk to him, but sounds like it could keep two guys busy for 6 months, and I know which welder I would rather listen to for that long. Having two running nearby seems to quadruple the "get on your nerves" factor.
    Scott
    Jun 2006
    Beaverton, OR
    5,459
    51
    There are also specific dual operator engine driven machines. We had an old MultiQuip diesel at work that allows two operators with separate controls for each. Miller still makes one too. http://www.millerwelds.com/products/.../miller_du-op/
    I think most of the companies have stopped making the splitters instead selling racks of inverter welders or racks with a single transformer and multi outputs.
    http://www.millerwelds.com/products/multioperator/
