John Madarasz
Stainless
- Jan 1, 2007
- Exton, PA.
Considering trying to cut through some 3/4" cast iron on a repair I'm doing...I'll need to cut through not only the 3/4" cast iron, but also some nickel rod repair in the same area. I have a tip for my torch that's rated for 1"...should I even bother trying, or look at another avenue for repair, refab of part.
I can post pictures if needed, but really just want to know if it's possible to cut cast iron and built up weld. This is s structural repair...a broken foot pedal arm on an old heavy duty hollow chisel morticing machine that gets a lot of use fwiw
