Spud
- Jan 12, 2006
- Brookfield, Wisconsin
Down here in Ceylon I got security spikes/grill on wall.
Need to weld some 0.5 inch diameter steel rod to the spike assembly. Had a choice between Mild Steel ad Bright Steel. The difference between the 2 is as follows:
Mild steel would bend more before breaking than Bright Steel
Mild steel has a rougher surface than Bright steel which has a somewhat smooth polished surface
Mild steel not as strong as Bright steel
I choose 0.5 diameter Mild Steel for its rougher texture and ability to bend before breaking.
Did I made the right choice?
Project involves welding several 17.5 inch long 0.5 inch diamater rods (represened in red in below pic) to wall security spike assembly. 10 inches of the steel rod will be inserted into the wall from the top (i.e. vertically ) into holes drilled into the wall.
