Booster
Cast Iron
- Mar 18, 2005
- Springfield, OR
Hello, im having some difficulty selecting a beed blasting or sand blasting set up. I have old propane tanks i cut up and recycle to make into little stoves. I have one quality issue left to weed out. Rust. I cannot seem to get every nook and crany with wire wheel, or power sanding, and even some micro pockets remain that promote rusting underneath the coats of paint i put on. I was told that sand blasting or beed blasting would be the next most thorough, fastest, and economical method for doing this correct?
If so, i wanted to know what you all would suggest. I thought that sand blasting would be nice except that i would probably construct a small outhouse size booth with a blower and air filter attached, to contain the dust. Either that, or i might construct a smaller booth just to fit the stove body's into, and find a way to attach the hose from a sand blaster. I think a sand blaster would be nice because its portable and versital, so i am leaning toward that, but would definately need to build some confinement for the dust.
These will be a constant production type item, so this is a long term thing, but i also dont want to buy more than what is needed for this job.
So, given that that would work, what would be the best size compressor and sand blaster that would do this job, and do it fairly quickly and efficiently. I would like to sand blast each tank outside only, and be done with it well within 20 mins.. Am i looking for CFM, or PSI, or both. What size tank would give me that kind of duration and power?
Here is a local pickup only, ebay item i was looking at, would this size of compressor be enough?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230194770552&ssPageName=ADME:B:WNA:US:1123
Thanks.
Thanks.
