Power roll for welding round parts
Results 1 to 7 of 7
    Sep 2017
    Ohio
    46
    10
    Question Power roll for welding round parts
    Anyone have experience or recommendations with small power rolls for welding various rollers/ round parts? I'm looking for something with around 3 inch minimum part size and ideally a foot pedal variable speed control. Something that uses a standard tig welder foot control would be good. Any suggestions? I see Lincoln makes one that will do 2 in to 16 in for $1500 msrp. I'll check with our lincoln supplier on price but not expecting much better... best I could get out of him when I bought a new torchmate 4800 was him to sell me a Viking 3350 helmet at cost
    Jan 2010
    Indianapolis
    1,132
    653
    348
    Investigate powered conveyor sections (used). Usually has 3/4 hp with VFD for regulation.
    Don’t use “welding positioner” as intended use; the seller doesn’t need to know, doesn’t need to google for comparable pricing.
    You’ll end up with a ten foot section to be modified as needed.
    I wouldn’t worry about arcing the bearings, you’ll have plenty of spare rollers.
    Motionguru should have an opinion on this, ask him.
    eBay - Page Not Found
    Jun 2015
    CANADA
    British Columbia
    1,034
    238
    544
    I've made a small system out of a worm drive motor and speed controller. The spindle is threaded to accept one of my lathes chucks and accessories.
  4. Likes Pete Deal, sfriedberg liked this post
    Oct 2005
    erie,pa
    8,353
    15211
    4063
    Same here:
  6. Likes Pete Deal liked this post
  7. #5
    Jan 2017
    Utah
    7
    8
    I have been wanting to fabricate me a potters wheel style turn table for my tig table for small parts. Nots sure if it would fit your needs. Check out txvikings videos to see his in action> #WELDA 8 3 216 Welding 118 And The Turntable Deciphered - YouTube
  8. #6
    Oct 2005
    erie,pa
    8,353
    15211
    4063
  9. #7
    Dec 2004
    uk
    11,970
    3220
    5243
    I have a home made rotary pipe bender, for a while i had a lovely job using it and a simple locator to center the part not even a chuck, welding discs on the end of short bits of 3" 16 gauge tube, in effect creating - replicating what was a deep drawn item. With a nice slow gear motor given a constant RPM, Tig torch gaffa taped to a DTI stand and a back purge through the middle of the table the results were near bloody amazing, was doing batches of a 100 a time, first 100 by hand took a fair bit of clean up as the OD had to then be polished out to a nice radius. Motorised potters wheel setup and a couple lobbed in the bin dialling in the settings and the result was untrue, i could polish 1 in the time one took to weld, made a killing on that job per hour there after! Smooth constant rotation makes for a really nice weld. Only thing i would add is you need seriously low speed and smooth motion, think just a few RPM, but the smoother the motion the better the weld!
