aussiebushman
- Feb 23, 2011
- Jerrong, NSW Australia
When a thread was stripped in an aluminium engine block, I tried to drill it out for a larger bolt - inevitably, the drill wandered off-center and went through the outside of the casting so now it leaks coolant. The engine is still in the vehicle and I live 40 miles from the nearest repair shop so a DIY fix is the only answer. This is my old unregistered "bush basher" It is very necessary around the farm but not worth spending heaps of money - it just needs to go again
I made an aluminium plug in the lathe and it fits OK but brazing was hopeless - just can't get enough heat in to to make the aluminium rod flow into the joint. My current plan is to bond the plug in with dynagrip - a high temperature bog - necessary because the hole is right above the exhaust manifold and I doubt "ordinary" thickened epoxy will withstand the heat.
Can anyone suggest whether putting a shorter plug into the hole then filling to the top with the stick welder might be better?
