trubble2rubble
- Aug 8, 2004
- Burlington,NJ
Welder is about to stick weld an assembly together when he is called away. The welder (Miller 320A, 220V 1 phase) is switched off, and he puts the grounding clamp on a nearby bandsaw (110v)which is plugged into an outlet via an extension cord. A few minutes later, a hot, plasticky smell is detected and smoke is seen pouring from an electric box on the bandsaw. The bandsaw is unplugged, and after the smoke disapates the grounding lug on the bandsaw plug has melted plastic around it, and the extension cord is fried along it's entire length. After it cools down, the bandsaw actually works as before. Where did the juice come from? Something like the grounding clamp being neutral instead of ground, or is there something wrong with the Miller 320?
t2r
t2r
