cyanidekid
Titanium
- Jun 4, 2016
- Brooklyn NYC
I am currently doing a gig as a repair/consultant with the manufacturer of some high end kitchen gear that is subject to high heat (400+f). the welds they are currently laying down are very tidy "sanitary" welds, perhaps autogenous (no filler added), but not sure.
very small welds, deeply concave, with very little ripple, actual weld root thickness often something like .015-.030" (on 304 14 ga)
not surprisingly, they break.
I have recommended tripling the weld cross sectional area, repeatedly, with pictures, with limited success .
the question at hand is; is there any risk of greater cracking if one used 309 filler (instead of 308)? I know that some welds are better "under matched", such as many chrome/moly (4130-4140) tube structures, where the greater ductility of an ER70S-2, (or -7 as some have recommended) greatly reduces the chance of weld cracking.
the austenitic nature and greater tolerance for carbon of the 309 should reduce the chance of cracking even though the UTS of the filler is slightly greater, and it is an "overmatch", I think? what do you say, any experience with this?
thanks in advance
thanks in advance
