Tig Welding Thin Wall SS Spheres Together?
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    Aug 2004
    Boulder, CO uSA
    98
    Default Tig Welding Thin Wall SS Spheres Together?
    I have to tig weld a series of 7" or 10" diameter stainless steel spheres to each other. The wall thickness is .047".
    How would you guys suggest doing this? How would you get close enough, since they are making point contact to each other? What size electrode, amps, rod, etc..
    Any help would be appreciated,
    Jay
    Dec 2008
    NE OHIO
    1,409
    13
    279
    Quote Originally Posted by JHW View Post
    Jay
    Can you get inside of them to spot weld them?
    .047 is not bad to tig.
    Aug 2004
    Boulder, CO uSA
    98
    I can not get inside the sheres, since they are full spheres.
    I just realized that I could use my Mig welder with SS wire. Do you think this would be better than using Tig, since I could get in closer by using a longer stick out?
    Jay
    Mar 2004
    Edison Washington USA
    10,148
    849
    4713
    I did this last year.
    It sucks.
    Stainless warps big time when you weld it, just the nature of the beast.
    I recommend a lot of tack welds, evenly spaced.
    What I didnt do, and probably should have, is drill holes, and make some kind of removable clamp system- maybe Cleco based.
    As it was, I ended up tacking, prying up low spots, pounding down high spots, and then grinding, filling, grinding, filling, sanding, filling, and so on. Repeat as needed.
    I was lucky that, in the end, I could needle scale the whole thing, for a slight texture, so you couldnt see that they werent perfect. If it had to be polished, it would have been even more work.
    These spheres are something like 12" in diameter, as I recall. The upside down bell shape is bigger, around 22", but its aluminum, and was a lot easier. The upper picture actually makes the seam stand out more than it really does - the light hits it just right.
    I used a pretty small tungsten, 3/32, mostly. 1/16" filler rod. Let it cool a lot and move around a lot- it warps when it gets hot, so you want to keep it from getting too hot. No long beads.
    Aug 2004
    Boulder, CO uSA
    98
    Ries,
    It sounds horrible what you had to do! My situation is worse since I have to weld the spheres to each other.
    I'm thinking now, maybe forget welding and trying to find some industrial adhesive that would stand up to outside weather conditions and the sun? Do they make such an adhesive?
    Jay
    Mar 2005
    Kansas
    6,692
    355
    2878
    I've seen smaller ones for fighter planes. They were electron beam welded.
    Mar 2004
    10,148
    849
    4713
    I wouldnt trust a glue edge to edge.
    It might be possible to cut a backing strip, and then use the fancy 3M doublesided foam tape- they use it to put the skin on buses and subway cars, it really sticks.
    But in the end, welding is probably the best.
    One trick people do sometimes is put the piece in a tub of water, with only the part you are welding sticking out- keeps it cool and keeps it from warping as badly.
    Mine actually turned out okay in the end- and they are about 20 feet up, so people dont look too closely.
    Jan 2009
    Savannah, GA
    36
    How about Silver Brazing with some 45%? Much lower temp should keep the material from warping. depending on how they need to connect you could even drill holes and use some rod to create some kind of bridge that the filler would like even more than just the two spheres touching each other. That would be hella strong.
    ken
    Nov 2011
    Pittston, pa
    506
    41
    103
    What is the aplication? Do the welds get ground and polished for sanitary use? How close are the tolerences? If its an art project, it should be very simple for you. If demensions matter then you better have your act together. Mig welding it will be very tough, Especially if the gaps are not perfect. How many of these do you have to do?
    Nov 2006
    ABQ, NM
    1,210
    13
    40
    Would it be possible to make a hole in each one and then weld a little strip inside that has a nut welded to it? Then, you could put a piece of threaded rod between them and thread them together. It sounds like the two just need to be held together and aren't anything structural. Threading them together might not be too noticeable.
  11. #11
    Dec 2011
    Idaho, USA
    186
    521
    100
    Quote Originally Posted by ions82 View Post
    I was thinking of something similar.
    How about welding a threaded stud onto one, then drilling a hole and flush welding a nut so you could spin the two together?
    I'm not sure what the application is, but if you did it right, you could enchain them.
  12. #12
    May 2011
    4,391
    599
    1793
    Weld a nut to one and a bolt to the other.
    Than screw together.
    You can cut the nut into the one and the head of the bolt on the other.
    I can see that i type to slow
  13. #13
    Jan 2008
    king george, va
    708
    151
    68
    Can you drill a small hole in them, fill them with water, weld together, drain and patch the holes. Shouldn't warp as the h2o will carry heat away.
    Maybe drill one, weld a cap nut in the hole, drill the other, weld a stud in it. torque them together with permanent locktight.
    Ben
    You too Heavey Metal, you beat me.
  14. #14
    Jan 2012
    Nebraska, U.S.A.
    646
    239
    155
    Can't remember the name but I think they are called nut serts?
    Its basically a threaded rivet, uses a tool similar to a rivet gun, doesn't leave much of a hight....
    Drill, nutsert, all thread with red loctite?
  15. #15
    Jan 2012
    Nebraska, U.S.A.
    646
    239
    155
    Quote Originally Posted by xdmp22 View Post
    Yup, nutsert
    http://www.aboveboardelectronics.com...nd/nutsert.htm
  16. #16
    Sep 2004
    Louisville, KY
    1,140
    314
    362
    The sphere shape should be more resistant to warping, no?
    Maybe tig without the nozzle with two inches of stickout and two argon hoses flooding the area (or weld in a glovebox)
    You're going to have to 'bridge' the gap no matter but you could get a uniform bead I would think.
    -James
  17. #17
    Dec 2011
    Idaho, USA
    186
    521
    100
    If applicable, you could also cut a short length of pipe to go between the spheres to increase the welding surface as well as get that surface closer to the nozzle.
  18. #18
    Aug 2004
    Boulder, CO uSA
    98
    Originally Posted by jamie76x
    "What is the aplication? Do the welds get ground and polished for sanitary use? How close are the tolerences? If its an art project, it should be very simple for you. If demensions matter then you better have your act together. Mig welding it will be very tough, Especially if the gaps are not perfect. How many of these do you have to do?"
    Jamie,
    This is for an art sculpture consisting of about 60 spheres, each one touching one or two others. My concern, aside from the warping due to the heat, is how do I get the end of the Tig torch in close enough to the point of contact between the spheres? Why do you say Mig welding will be very tough?
    The ideas of bolting the spheres together will be tough because the 60 spheres are in closed loops and are unsupported except for each other.
    Thanks to everyone for the interesting ideas,
    Jay
  19. #19
    Dec 2011
    Idaho, USA
    186
    521
    100
    Jamie,
    Jay
    With that many spheres, I think you should use short sections of pipe between them. It will make the welds way stronger/easier, and will also help you position them.
  20. #20
    Aug 2004
    Boulder, CO uSA
    98
    Quote Originally Posted by Curious Yellow View Post
    This sounds like a great idea! Thanks!
    Now to deal with the warping problem. Do you think the sphere shape will resist the warping? I guess if I'm very careful and do small tack welds, this will help.
    These spheres are expensive, so I do not want buy them and then find out that it's not going to work.
    Thanks again,
    Jay
