Torchmate help please!!!
Results 1 to 7 of 7
    Dec 2017
    Indiana
    Default Torchmate help please!!!
    I run a torchmate xs2. For some reason, my main program decided to reset itself, and is now adding 1.5 inches to everything i cut. I know its in the programming, but i cant figure out where?
    Oct 2005
    erie,pa
    8,357
    15215
    4065
    God this is gonna be like pulling teeth...
    When does it make the 1.5" offset, only new cad files ?
    or take an existing file (that you have already run before) ?
    There's a couple things going on here, need to separate them out.
    Dec 2013
    New Hampshire
    133
    44
    68
    I dont know about the torchmate xs2 but if it uses there torchmate cut software
    You probably have a setup file saved somewhere try <file> <open setup> and look for a .stp file
    If that doesn't work your configurations will be in <configuration> <machine> <mechanics>
    Dec 2017
    Indiana
    It only does it to existing files.
    And i dont have a mechanics tab under machine...
    Dec 2013
    New Hampshire
    133
    44
    68
    If it is only doing it to existing files what happens if you re-import the DXF file?
    Dec 2017
    Indiana
    Its now saying i have to select a new setup. And torchmate tech support is a damn joke...
    Dec 2013
    New Hampshire
    133
    44
    68
    Im surprised, I have had really good luck with Torchmate techs.
    What version of there cut software are you using?
