welder689
- Sep 18, 2006
- Central New York
I'm in the process of building a 6'x10' (approximately) utility/landscape type trailer.
For the perimeter of the frame, I plan on using 2"x3" rectangular steel tubing with a wall thickness of 14 gauge (.078").
I'm using a Class III A-frame style coupler. For the tongue material (from the main frame to the coupler) I'm also using 2"x3" rectangular tubing, but for this I'm planning on 11 gauge (.125"). I plan on running this right under the frame, on both sides, until it reaches the side members and welding with either MIG and .035 wire 75/25 gas or maybe 7018 since it is the coupler.
What do you guys think? Will the 14 gauge frame be sturdy enough? The cross members, to hold up the decking will be 1.5"x1.5"x1/4" angle.
I plan on putting a railing around it out of 1.25" square tubing.
Trying to use material that I have.
Any input appreciated. Thanks.
