HWooldridge
Hot Rolled
- Aug 29, 2005
- Central Texas
I have a small ongoing production job that requires me to TIG a piece of stainless bar stock to a piece of lightly galvanized steel and I have never had an issue doing this prior to today. I was happily welding along when the puddle "fizzed" and the arc changed color. I stopped to flip up the helmet and noticed a glob of material had jumped onto the electrode. There was also a corresponding low spot in the weld. I concluded the electrode had simply touched the puddle so I broke off the lump, reground the tip and went back to work. A couple beads later, the same thing happened. I said a bad word and repeated the electrode dressing. Three or four welds later, it happened a third time. By this point, the electrode was pretty short and I was insane with rage so I went to the box to get a new one. After changing the electrode (which came from the same box as the other one), the problem went away and did not happen again over the course of about 20 more welds.
I'm stumped - I may have touched the puddle in the first instance but I'm pretty sure it did not happen the second and third times. The only thing I can think of is that the whole electrode was somehow contaminated but I have never seen weld metal jump to the electrode unless the puddle is touched. Has anyone had a similar experience or am I just whacked out today?
