jinglejangle
- Jul 16, 2008
- wisconsin
This is my first welding post. I need some tips and assistance. I am working on welding a mobile cart for a piece of woodworking machinery. The stock is 2"x4"x1/8" box tube mild steel. The setup is a lincoln 255 mig welder, 75/25 argon mix, .035 wire with a 200 feed rate and 17.8 volts. I am working on some test welds for capping the open ends of the stock. The end plate is 1/8 inch mild steel. I have tried cutting a matching 2x4 plate with an 1/8 inch gap, no gap, slightly oversized plate and grinding it down, and a relief ground piece with a matching sized end cap. Several things are happening. The weld is piling up and I am burning through. I have slowed down both the feed rate and the voltage and sped up the welding pass. The rest of the welds for the cart look great.
My question?
Is there a proper setup and technique to weld an end cap to a piece of matching stock so it looks ok?
Thanks for the help!!!
John
My question?
John
