So just for the sake of experimentation i decided to try using Co-2 instead of the usually preferred Argon mix, for MIG / MAG welding. Some folks do; thought i'd give it a try.
What a surprise when I found that the bottle has a completely different thread... the regulator doesn't fit.
What? Why would they do that? (I'm overseas, so specific brands are meaningless, but still-- they must do this on purpose. Why?)
So, I just made an adapter piece of correctly in / external threaded brass, of the usual suitable-for-machining-nuts 'n' bolts and mechanical bits brass alloy hex stock. Minimum wall thickness anywhere on the piece is 2 mm. Ideally this area won't be pressurized, but still...
Do I really want to put 200 bar into that?
Not so sure...
Not so sure...
