Dave K2
Stainless
- Apr 18, 2007
- Hertfordshire, England
Ok, time for some p***taking
Finally managed to get some play time tonight,
3mm steel, 90A, 5lpm
Autogenous (sp) beads....
Beads with filler rod, too slow at front?
The back, lots of penetration?
Then I thought, what the heck, and tried a fillet, 110A
I tack welded the ends first, this worked beautifully, then tried a run but found the rod favoured one side or the other, so I cheated and went over the top, this is the result above. Whether or not it's the done thing, I was most impressed at how easy it was to reflow the mess, add a bit more get a possibly usable result?
Things I've learnt...
The torch seems awkward to hold and move, I tended to use my wrist than slide along?
It puts a massive amount of heat down, not sure what I was expecting but damn hot!
There's lots going on, kept forgetting to feed the rod and ended up with a red hot glove
Considering it's my first time ever with tig, what you reckon?
I found it much more enjoyable than Mig and that's fun, being able to see what's going on was good too, watching the metal pool up and the rod flowing in is good. No spatter, much slower, time to think, excellent fun.
So suggestions please, obviously need to practice beads while moving but what's a good thing to do???
Oh and I only dipped the tip once
