Results 1 to 7 of 7
Thread: Slice Torch
    blake in spokane is offline Hot Rolled
    Jan 2008
    spokane
    786
    Default Slice Torch
    I'm looking at buying an Arcair Slice torch to blow out stuck pins. What size collet/electrodes do I need & what about collet extendions? And any other info. will help. Thanks - Blake
    macona's Avatar
    macona is offline Diamond
    Jun 2006
    Beaverton, OR
    5,442
    Heres a link to the catalog for the slice torch:
    http://www.thermadyne.com/IM_Uploads...89-240-003.pdf
    You should give an application engineer a call at thermadyne. They should be able to tell you what you need to know.
    Be sure to buy a set of fire-proof gear. These things throw molten metal and slag big time.
    dave powelson is online now Aluminum
    Aug 2007
    Yuba City, CA
    195
    Default arc air
    Quote Originally Posted by macona View Post
    Amen! And watch 'where' you're blowing this stuff. It can be white-hot!
    GoldenChild is offline Plastic
    Jan 2008
    Golden Colorado
    24
    Quote Originally Posted by blake in spokane View Post
    the kit I have has collets for all the size rods they make some rods have a bell on the end to connect more than one rod together
    piercing pins an be tricky........ but for by standards who have never see it done before it can be an awesome thing
    Stuart Caruk is offline Stainless
    Feb 2007
    Ridgefield, WA
    1,028
    Slice torch, brings back fond memories...not!
    Actually many years ago I used to do a lot of fabrication and repair. My least favorite was getting the tracks apart on a machine I couldn't get to the shop where I could rig up a portable pin press to press it out. Wailing and beating on the pins never worked well. Trying to cut them out with a torch made too much touch up repair work later.
    I've used big slice rods (5/8" thick and 10' long) to pierce thick plate (6" +) that I cut on our CNC oxyfuel table when I needed a peirce hole, so I went out and bought a slice torch. You can stuff it right in teh center of the master pin on one end and keep feeding the sucker through the center till it pops out the other side 8 or 10" later. You may need to change the rod, but it's not a big deal. It will throw crap everywhere till the hole gets established, then it's not so bad. the coolest part is that the pin shrinks to the inside about .005 and you can usually tap them out with a hammer.
    the best was when you get a farmer that has beat and beat, and hacked, and heated, and beat some more on a pin that won't come out, and you take your slice torch to it, and a couple minutes later the pin is out.
    After a while you never do it while you're watched. They don't feel like the value is worth it. I still have the torch, but rarely use it anymore. It comes in real handy a couple times a year though. It's great for getting rebar out of concret, and does a pretty good job of melting through a concrete wall. Now that throws crap everywhere.
    Incidentally when piercing thick plate I used to weld a cap on a big hunk of tubing with a large hole in 1 side and run the rod through the cap. Start it up and set the tubing over the pierce hole, aiming the hole in the side at a suitable palce to throw molten chunks of metal and let her rip.
    Jan 2008
    spokane
    786
    Default Slice Torch protective Gear
    What are some of the brands, types, of gear to use with Slice Torches?
    macona's Avatar
    Jun 2006
    Beaverton, OR
    5,442
    Search for protective gear used in foundries.
