Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By PracticalMan
Thread: Machining 718 Inconel at High Speed
    PracticalMan is offline Super Moderator
    May 2009
    353
    Default Machining 718 Inconel at High Speed
    Extremely hard materials can be vexing to work with mistakes are very expensive simply because of the cost of the material. This video was sent in by a machinist that has worked with high speed and advanced materials for more than 20 years. It is not uncommon for people to run inconel at SFM of about 50. This video shows that it can be cut at 4,000 on a rigid machine provided the set-up is right. It requires the right programming, tooling, tool holder and a fast, rigid machine. All of these components are critical to the success of this application. If one variable is wrong it could fail. This is a pretty impressive cut that was used as a demo live at IMTS in 2006. The set-up used is listed below.
    • Material: 718 Inconel
    • Machine Okuma MB
    • Kennametal ceramic inserts
    • BIG Kaiser, Big Plus Holder 1 1/4'
    • 4000 SFM
    • .002 Chip load per tooth
    This video is presented courtesy of Hardmilling.com
    jdj and danielcedillo like this.
    mori is offline Plastic
    Jun 2009
    ny
    Thumbs up nice work
    its good to see people move faster not slower with the super alloys. how many edges on cutter? and also how deep the cut?
    gsjohnny is offline Plastic
    Jun 2009
    connecticut
    how much white layer is there after machining?
    Brazos's Avatar
    Brazos is offline Plastic
    Feb 2010
    Pearland Texas
    I can't view the video.
    Brazos
    Brazos's Avatar
    Feb 2010
    Pearland Texas
    Now I can that's cool.
    Brazos
