Results 1 to 2 of 2
    PracticalMan is offline Super Moderator
    May 2009
    353
    Default The Versatile DS-30SSY Dual-Spindle Turning Center With Y Axis
    The Haas DS-30 Series Y-axis turning centers combine dual-spindle turning with Y axis, C axis, and live tooling to create powerful "done-in-one" machining solutions for any shop. The opposed spindles support fully synchronized turning, and allow on-the-fly part pass-off to reduce cycle times. The machines provide 4" of Y-axis travel for off-center milling, drilling, and tapping, and come standard with high-torque live tooling and a servo-driven C axis for versatile 4-axis capability.
    The DS-30SSY has a maximum capacity of 16" x 23", with a 30hp main spindle and a 20 hp secondary spindle. Both spindles turn to 4800 rpm, and have a 2" bar capacity. A 24-station hybrid BOT/VDI turret is standard, and Z-axis rapids are 945 ipm.
    snowshooze is offline Plastic
    Sep 2010
    Anchorage, Alaska, USA
    Wow. That was pretty good. What does one of these jiggers go for?
    Thanks for putting this up.
    Mark
