Does anyone know the forumula for working out the linkage lengths and pivot points to obtain ' Akermann ' steering geometry ?
At least I think its called Akermann steering - that is, when a vehicle turns, its inner wheel follows a circle with a smaller diameter than its outer wheel does. To acheive this the Pittman Arms ( as auto makers call them ) are angled inwards. This causes the inner wheel to move through a greater arc than the outer wheel as the steering wheel is turned ( its easier to understand if you actually see it happen ).
My problem is in how to work out the actual ratios and pivot points when building a steering linkage system. I've looked on the web but came up blank.
Any help will be apperciated so much, it'll make you sick!
