3 Phase switch for 2-speed motor
Results 1 to 11 of 11
    Apr 2005
    Central MA
    1,122
    72
    214
    Post
    Hi;
    I need a Three position (off, lo, hi) switch for a 3phase 2speed motor. The original was some odd Europeanone (Mueller?). Does anyone know of any online places to look for this?
    TIA,
    Jon P.
    Mar 2002
    Scotland
    4,240
    1019
    469
    Post
    Possibly Klockner Mueller.Was it a rotary cam switch?If so there should be a part number around the top segment under the flange.Hundreds of variations of these available but should not be a problem to replace if you know the part number or the type of windings in the motor.
    regards,Mark.
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1003
    Post
    http://klocknermoeller.com/?OVRAW=kl...OVMTC=standard
    Also, the drum switches I've been involved with had several wiring diagrams under the coverplate to show how to hook up the switch for all kinds of different 2 speed and reversing applications. It depends if the drum switch can be externally mounted or you are trying to do more of a cosmetic replacement where the switch was buried in a purpose-built cavity and the wiring runs internal to the machine.
    -Matt
    Jan 2003
    Pleasant Hill La
    225
    Post
    I am not sure what you have but several years ago I bought a 17 X 55 lathe that had a 2 speed motor. The owner told me he removed it from the shop due to having so much electrical problems with it. After about a year I decided I'd see if I could fix it. I removed the panel and started drawing a schematic. What I discovered was the motor ran in a Wye connection for one h.p.-speed. It ran in a delta connection for the other. I changed out the burned control contacts that had been the problem and use the machine fairly often with no problem. Just to say, this may be the way yours is wired.
    Jul 2004
    Asheville NC USA
    8,949
    3405
    2982
    Post
    Not sure about European stuff, but in the US, 2 speed 3 phase motors are available as 2 speed single winding and 2 speed, 2 winding. Its imperative to know which one you have before connecting it to a speed switch or 2 speed starter. A mistake will smoke the motor in short order. We won't go into the details of how I know this
    Apr 2005
    Central MA
    1,122
    72
    214
    Post
    Thanks everyone for the replies. It may well be Klockner Mueller. I will look in a few minutes. As to what windings, Well, the motor has two sets of connections {u,v,w} ands {x,y,z), so I am assuming that the switch takes the incoming 3 phase and switches it to either of these two sets, or to nowhere for the off position.
    This all started when I accidentally pinched the armored cable to the head of my Rambaudi. It was a little too long and flopped in the way. I was pretty intent on what the cutter was doing, and didn't notice it. It wound up shorting out a wire and breaking the casing.
    I replaced the whole thing with flexible conduit.
    But when I was removing this Mueller switch to do that, it fell apart.It is a modular thing andthe end cap came off allowing all the guts to come out, including all the little red cams. :mad: :mad: I don't believe I can put it all back together again, it might have used special jigs at the factory. I also blew out one of the fuses. It sits in a wierd ceramic fuse holder. When one of these fuses go, a little pice of metal pops forward, which you can see through a clear part of the screw-in capwhich holds the fuse. Anyone have any idea where I can get these??
    regards,
    Jon P.
    Jan 2005
    waverly nebraska
    91
    Post
    Jon-
    As someone else already determined what you probably have is a Klockner-Moeller switch. If you can find a part number on it I can probably help you find where to get one or a equivelent of another make. As far as the motor wiring goes, the best thing to do is get the nameplate info off the motor, hopefully it's eiher american or one of the more common european makes.
    Unfortuanately I know exactly what you're talking about with those fuses. The only place I've ever seen those was in a Toshiba molding machine. I used to have to buy them for it, but I don't work there anymore and it's been about 12 years since I did. I'll have to do some thinking about that. Hopefully there's some information on the fuse, voltage and amperage at a minimum.
    Take care, I'll see if I can find something on the fuses.
    Bernie
    Jan 2005
    waverly nebraska
    91
    Post
    Jon-
    Regarding the fuses, I'm pretty sure they are either Diazed or Neozed fuses. Both match your description. I located a place on the web that says they have them. Maryland Metric, mdmetric.com. If you give them the dimensions of the ones you need they should be able to identify them.
    Take care
    Bernie
    Mar 2002
    Scotland
    4,240
    1019
    469
    Post
    Jon,take heed of metalmunchers statement,the same applies to european motors.I`ve got a Rambaudi mill,I can have a look at the motor if it`s the same.What model is yours?
    regards,Mark.
    Apr 2005
    Central MA
    1,122
    72
    214
    Post
    Bernie;
    Thanks for the hint on the fuses. I will measure mine tonight. They look somewhat like the ones in the SIBA catalog.
    Metal;
    I have a Rambaudi V2.
    Thanks folks!
  11. #11
    Apr 2005
    Central MA
    1,122
    72
    214
    Post
    Folk;
    The switch was a Klockner Mueller. It is clearly a replacement for an even older original. I was able to read the part number, and KMparts is contacting the factory. Unfortunately it is a custom job. So big $ and time I am sure.
    The fuse is still a bit of a mystery. It is 2in by 1/2 dia, and has a self indicating little bit of stuff the pops off if it blows. These are apparently called cylinder fuses. There are at least two styles of similar shape. One of them was specifically used in Italy. Yeesh. I will probably have to order this from somewhere as I doubt anyone carries it locally ???
