Luke
Hot Rolled
- Aug 23, 2003
- Nevada,Iowa
The factory that I work in had used Marvel Air-Tool oil for years but in the last year has switched to stocking Mobil Almo 525 Air Tool oil. We use this simply for pneumatics lubrication (when remembered) on the machines. The Marvel oil seemed a bit less viscous, red , and seemed to work fine. The Mobil states that it SAE 20 and that's about all I know. I'm curious how the two compare for seals, spools, etc. Our ail quality is usually very good and dry but there are times when water will enter the system or something will let loose in that Chinese pipe.
The cylinders that we use in my area of concern are typically disposable Bimbas, Numatics and a few high dollar linear cylinders. Valves are mostly MAC and Festo. I have been noticing that some of the response times for actuation are not always what it should be and a lot of the flow controls tend to need too much attention for consistent speed control.
What do you guys think about this change? Is the Mobil "good stuff"? The Marvel seemed to be a lot lighter oil (and red)and I'm wondering if that lighter oil would work better for the flows and spools.
I also suspect some of the "shift guys" lubing "dry cylinders" with Tri-flow when they get a call to a down line. I have not verified this -it's just a hunch. What if any damage would Tri-flow do to a pneumatics system -seals, etc?
What air oil do you guys recomend and use?
Thanks for the opinions.
Luke
Luke
