Aluminum shaft collars
Results 1 to 5 of 5
    Apr 2005
    Bay Area, Ca
    1,372
    11
    167
    Post
    Does anyone know where to get aluminum, doublt bolt shaft collars? I need to use them to hold some bearings, and they have to be aluminum since they will be welded to some aluminum tubes. Yes, i could make some, but it seems like a waste of time if I can buy them anywhere.
    Nov 2005
    Maryland
    8,502
    741
    1055
    Post
    Try McMaster-Carr http://www.mcmaster.com
    They have lots of shaft collars, including some in aluminum.
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,034
    423
    991
    Post
    I may be stating the obvious here, but you can only weld one half of a 2-bolt shaft collar if you ever want to release it in the future. Fabricated as such, it sometimes leads to poor results because it can get tweaked more easily during an overload.
    Also watch the alloy, I have no idea what the aluminum collars are made of, but interestingly McMaster bills the 12L14 or whatever free machining steel is used for the 2-bolt steel collars as "alloy steel" :rolleyes: One of their few transgressions in my book, despite the free-machining material, they seem to weld reasonably & durably with special rods or just plain MiG.
    -Matt
    Adding: again, could be obvious, but I'd make all attempts to weld first and then machine the bearing bores later with a little undersized material to clean up any warpage or misalignment.
    Apr 2005
    Bay Area, Ca
    1,372
    11
    167
    Post
    Thanks y'all.
    Yeah, I will try to weld first, machine later, however it will mean I'll have to use my buddy's 28" lathe, since the collars will be welded to 13" shafts. Edit: Oops... duh, I can indicate them in on a mill and use a boring head...
    Only one side of the collars was going to be welded. No worries there.
    Feb 2003
    Russellville, AR 72802
    449
    6
    24
    Post
    Be sure to weld the half that has clearance holes. If the threads become stripped, it will be easy to replace.
