YoungDen
Cast Iron
- Feb 16, 2004
- Kiron IA USA
I have a compressor that is about 100 CFM. It is continous run by an engine. Would a 10 gallon tank be big enough to cushion the surge from each piston stroke so as not to open the unloader valve too much? I want to use the compressor for sandblasting. When the deadman valve is open, all the air should be used so the compressor won't cycle.
