Bearings "C3" Clearance
Results 1 to 11 of 11
    Mar 2003
    North Wales GB
    2,384
    Post
    Hi guys I'm also rebuilding my car manual gearbox/ transmission.
    I'm sourcing the bearings, other than, from rovers ...because the standard bearings had polymide cages ...and were not up to the job
    so sourcing steel caged alternatives.
    What's C3 clearance on a bearing ...would it be a suitable substitute for a car gearbox bearing
    The bearing chappy tells me it's clearance with extra built in for expansion etc ....this is the only one he is able to get as a substitute for one of them.
    all the best...mark
    Jan 2005
    CANADA
    Saskatchewan
    9,546
    1163
    3252
    Post
    The extra clearance may contribute a small amount of extra looseness to the shaft and gears (if any) on that shaft. That means a bit more noise, perhaps a bit less shock load capacity. But, if it is the only one he can get, well, what are you going to do?
    Mar 2003
    North Wales GB
    2,384
    Post
    Here explains it a bit ...
    http://www.cooperbearings.com/tech02.htm
    It's still got to be better than the very worn and very rough bearing i have there now ...me thinks
    the trouble with these bearings is that they are automotive bearings ..car manufacturers have deliberately changed the sizes from standard to achieve sales only from themselves.
    all the best..mark
    Feb 2004
    peekskill, NY
    23,731
    3906
    Post
    In many vehicle gearboxes the bearings are
    retained in bores in aluminum housings.
    The housing is heated to expand the bore(s)
    and the bearings drop in to assemble. When
    the aluminum cools off it locks the bearing
    race into the housing.
    It also compresses the outer race somewhat and
    that may be the reason for spec-ing "C3"
    clearance bearings.
    Jim
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    Post
    Watch them Cooper Bearings people. They have all their Fahrenheit to Celcius convertions wrong. If that's wrong, what else is?
    Mar 2003
    North Wales GB
    2,384
    Post
    I'm not buying from cooper bearings ...that's just a reference I found on the web..
    Most bearings in this box are a loose fit on the shafts and in the housings...I'm told this is normal for that box.
    One of them just falls off the coutershaft when inverted...I'm also told this is normal by the rover gurus ..although ..I find it hard to believe
    ...........thinking rover had a whole bunch (job lot for all the gearboxes) of shafts made up under tolerance.
    all the best.......mark
    May 2002
    Buffalo, NY
    105
    7
    Post
    Mark...Your last post states that the shaft is loose in the bearing inner race??? Why?? This would totally defeat the purpose of a ball bearing assembly to have a loose shaft fit on the inner race. It will only wear the shaft having it spinning on the hardened inner race. Same goes for the outer race pressed into the bearing bore. If its not a press fit or retained in some fashion it will wear out the bearing bore in no time. Your bearing C3 rating is for bearing class with the higher the number the tighter the tolerance of the matching parts, the less play in the system. Price some matched ABEC 7 bearings....cost an arm and two legs!! Best regards,Mark
    Mar 2003
    North Wales GB
    2,384
    Post
    HI mark
    I don't know a lot about the development and design of this box ...seems that bearings are intentionally a loose fit
    .maybe when the gears align ...they are subject to torque and thrust and whatever ...
    and all the clearances are taken up.
    maybe there is compensation for expansion and contraction..........I'm no gearbox expert ...I didn't design this one ...so I just don't know.........the designer knows ..but not I .
    All the best..mark
    Mar 2005
    Somerset, UK
    4,949
    408
    1496
    Post
    What's wrong with the temperatures, Forrest? Temp differences look OK to me.
    Zero F is near enough -20C to a shivering man.
    Feb 2004
    peekskill, NY
    23,731
    3906
    Post
    I take it you have the mfr's repair/re-build
    manual for this gearbox, it will be very apparent
    if they want interference fits for the bearings,
    they will say you need to heat the housing
    to X temp in an oven to get it apart.
    If they don't say that, then they want them
    to simply slip into the bores.
    Jim
  11. #11
    Mar 2003
    North Wales GB
    2,384
    Post
    Hi Jim
    here is a link to the manufacturors manual of the gearbox..
    bear in mind it covers two different boxes ...
    mine being the PG1
    http://www.newpcworld.com/cars/rover...box_manual.pdf
    alkl the best...mark
