Belt sander belts
Results 1 to 15 of 15
    Jun 2004
    Missouri
    304
    Post
    One of the handiest and most used tools I have is a "1 inch" belt sander.Original belts seemed to last forever.Went through some new Grizzly purchased belts very quickly from the glued lap becoming unglued.Glued some with Gorilla Glue which was better than the original but still failed fairly quickly.Is there a better glue or a better brand of belt?
    Mar 2005
    Central WI - ~USA~
    375
    Post
    Howdy Sophiedoc, As most of us learned, the inexpensive sanding belts are about a one-time use item. So, switch over to a name brand, when you see how long they last, you will find out that they are "less expensive" in the long run!. I still have a couple "cheapies" laying around, mixed in with my name brand, quality belts, and everytime I throw one on, instead of throwing it out, I get irratated. They may last about a minute, and, time to replace it, again, I hate that. Obviously, this is true with any type of abrasive - belt, sheet, roll, drum, disc, etc., buy quality, and be happy!. I quess this shows that most all American made abrasives are the best, though I would think their are some quality imports, but I am not familiar with any of them. Well, go thru your catologs and place your order now!!...
    Oct 2003
    Bonners Ferry, Id
    2,875
    572
    372
    Post
    How to spell relief: N O R T O N
    Apr 2005
    powell river bc Canada
    755
    37
    166
    Post
    I am using the Zirconia belts and have been impressed with the life i get.They cut very quickly when new so I cycle them and use worn belts for polishing.
    Mar 2004
    Edison Washington USA
    10,148
    849
    4713
    Post
    I really like the zirconia belts from Klingspor- we run em on all our belt sanders, stationary and portable.
    I use them exclusively on the little 1 1/8" x 21" makita sander as well.
    they last a long time, and cut anything.
    I think they are called CS411 at Klingspor.
    http://www.klingspor.com/
    $50 minimum order if you set up a commercial account, and you get wholesale prices. I buy PSA discs, hook and loop discs, belts, flap discs for little grinders, and just plain sandpaper from them.
    Or, retail prices, they sell to anyone thru their hobby division.
    http://www.woodworkingshop.com/
    Mail order em, they make em up to order in any size or grit, and they get to me in about 3 or 4 days.
    May 2002
    South Central PA
    12,621
    1635
    2779
    Post
    Ditto on Klingspor - Try 'em, you'll like 'em. It's our first choice, better than 3M.
    Feb 2004
    Reno, Nevada, USA
    37
    Post
    Thinking of trying the Klingspor on my 2" X 72" square wheel grinder. One quick question. Does the glued joint act like a "bump in the road"? I have used 3-M and another brand that in the finer grits have a definite bump. It's very annoying in doing finish work.
    Thanks in advance.
    Richard
    Feb 2005
    Castle Hayne, NC 28429
    115
    Post
    I have a cheap 4” belt sander. The belt that came with it was unusable because they overlapped the seam. Replaced it with a belt that has the seam butted together, rather then overlapped. Works a lot better now. Now that’s one more thing I have to keep in mind when buying new belts.
    Aug 2004
    New England
    2,222
    32
    158
    Post
    I'm no expert but have the idea that fresh belts keep their glue joint better than aged belts. perhaps humidity or heat over time degrading the joint.
    Any opinions?
    Northernsinger
    Feb 2005
    NW ARK
    161
    Post
    I always order butt-spliced belts. I have 3 2X72 belt grinders in the shop and run nothing but butt-spliced belts on all 3. They run smoother and do not have the "bump" you get with the cheaper lap-joint belt. This is critical when sanding with a platen. When using a contact wheel the joint is not as important, I just make it a habit to always ask for a butt-spliced belt.
  11. #11
    Feb 2005
    NW ARK
    161
    Post
    Another tip with a belt grinder. If you use a platen on your belt grinder and do any fine finish work with it go to an auto supply and get some 3M two sided tape and some sheets of cork gasket material. Clean the platen with a solvent and put the cork on with the 3M tape. This will put just a little "cushion" to the platen and results in a lot finer finish on your work. Also eliminates any bump from the belt. The first time I tried it I was really suprised how good it worked and how long the cork will last.
  12. #12
    Mar 2005
    midwest
    59
    Post
    As a further step to reduce heat buildup, spray the platen (cork covered or not) with that graphite-bearing spray. Seems to extend the life of the belt glue-joint.
  13. #13
    Aug 2005
    Central coast of CA
    91
    Post
    Several of the woodworking mail order folks sell the graphite pads specifically for the 6x48 belt sanders, very effective. especially with the 'blue belts'.
    Klingspore rules. I use them for everthing from sheets to hook & loop to the 6x132 horizontal belt machine.
  14. #14
    Aug 2005
    Bayou La Batre Alabama
    177
    Post
    Try useing a long strip of box tape on the back side .
  15. #15
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    Post
    On the Burr King (2x48), mostly for heavy stock removal, either the blue Zirconia or the reddish Ceramic (mounted on the machine) work well.
    Tru Grit has small minimums, good prices http://www.trugrit.com/
    Econ Abrasives ((800-367-4101) in Frisco, TX has no web site but offers low prices & fast service. Will custom make any belt, any size, any grit.
    Supergrit http://www.supergrit.com/ is really hard to figure out. Some items are brand new overstocks from big names (Norton, 3M, Klingspor, etc) - these are superb. Other times, some belts are made in-house and the joint is rough, edges don't match, etc. Can't beat the price, fast shipping, no-hassle return policy even if you use something & it breaks.
    Nonwoven belts are great for blending, deburring softer parts, and producing a satin or a brush finish. None of the cheaper belts are worth a nickel IMO. In 2x48, around $13 to $15 buys a good belt that lasts until all the weave is gone.
    Film belts, like the 3M TRIZACT, are long-lasting & cool cutting on hard to finish materials (composites, ceramics, some SS) http://tinyurl.com/dutva
    http://www.manufacturingtalk.com/gui...ive-belts.html
    http://www.powersourcing.com/sg/abra...forsanders.htm
    ________________________
    Barry Milton
