Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    fly_sd is offline Aluminum
    May 2006
    San Diego,US
    146
    Post
    I was thinking about using my HF 20T press to bend metal - any suggestions on what I can pick up to allow me to use this. The only suitable thing I've seen made for this purpose is rather expensive (around $280 or so form what I can see). Any other cheaper options?
    Hammer n Chisel is offline Aluminum
    Sep 2006
    194
    Post
    Metal?
    What are you talking about? Anything made out of metal is metal.
    Do you mean round stock or bar stock or round tube or pipe or plate or what?
    May 2006
    San Diego,US
    146
    Post
    Sorry - I meant sheet metal.
    surplusjohn is online now Diamond
    Apr 2002
    Syracuse, NY USA
    8,607
    Post
    do you mean a press brake attachment? 280 bucks sounds cheap to me,
    Ries's Avatar
    Ries is offline Diamond
    Mar 2004
    Edison Washington USA
    6,321
    Post
    I would agree- that sounds like the bargain basement Northern Tools price.
    the only thing cheaper is gonna be 3 pieces of angle iron.
    2 on the bottom, one on the top.
    Timw is offline Stainless
    Nov 2005
    N E Florida
    1,611
    Post
    I use my HF 20 ton to straighten steel all the time. I have straightened 1/2" steel plate brackets from under a street sweeper that hit a curb.
    The term you are refering to is called "Braking metal" or a metal brake.
    I have a 50ton Scotchman Ironworker. The brake attachment for it costs about $1000. I made my own from scrap. I used 3 pieces of 1 1/2" X 3/16" angle welded together in an upside down W for the bottom and a piece of 3/4" plate for the die. I made it 12" wide. I built a frame for the 3/4" to move up and down in.
    It will bend 3/16" X 10" or 1/2" X 3". I also use it for round bar. I have bent 3/4" round.
    Northern has a brake listed for presses but if you can fabricate you can save a lot.
    tsmartin_98 is offline Aluminum
    Mar 2006
    WA State
    96
    Post
    You can build one cheaper if you have the materials. I built the inverted W for mine but instead of using a piece of angle iron for the top piece I took a 3" wide X 1/2" thick flat and ground, didn't have a milling machine, one edge to an included angle less than 90 degrees. Then fabricated a way to clamp it to the ram. Using a piece of flat bar shaped like this allows a bit of over bend to compensate for spring back.
    TS
    Too_Many_Tools is offline Stainless
    May 2003
    1,124
    Post
    Anyone have any pictures of the press brake attachments that you have made?
    TMT
    BadDog is offline Stainless
    Mar 2006
    Phoenix, AZ
    1,295
    Post
    I made my own. Started by adding a 20T air over hydraulic cylinder - on sale for $69 as I recall.
    Then made a press brake attachment. Piece of 1/2" x 3 x 24+ steel I got from a friend. Had some sort of stamped pattern on it and it was hard as crap. Cut an 80* included point on one long side and stitch welded (keep down the heat, don't want to anneal) a back bone of 3/8 x 2" stock down the back side with a piece of roll bar scrap as an adapter socket for the press ram. 2 Jack screws on each side keep it straight and some pieces of scrap square tube keep it aligned with the vertical rails.
    The die is just a piece of 1/4" x 6" plate with 2 pieces of 1/4" angle iron inverted and welded with a ~1/4" gap between them.
    Finally, I added some "gibs" to my ram cross bar to keep it from shifting when pressure was applied.
    I've bent 16 ga 20"+ wide to 90*, 1/8" x 1" strap to 90*, and a fair bit of other stuff as well. Seems to work fine, but I wouldn't go much past 1/8" without a stronger die plate and more gap.
    May 2006
    San Diego,US
    146
    Post
    Yes, I was referring to the press brake from Northern tool. Did not make sense to spend that much on the attachment given the cost of the press. Ideally it would be nice to get a stand along brake but I do not have the room for one plus I do not do much bending. I have had a one of those little crappy 30" portable brakes for some years - it works quite well (suprisingly) on Al and I recently did a 30 deg bend on a 1/4" X 1" piece of steel - provided the press plate is firmly clamped it seems to work OK.
    However, since I also have the hydraulic press I thought using that with an attachment would make more sense. Making one sounds like a good idea.
  11. #11
    Mission Mfg. is offline Cast Iron
    Dec 2006
    God\'s Country, California
    498
    Post
    Timw
    I use my HF 20 ton to straighten steel all the time. I have straightened 1/2" steel plate brackets from under a street sweeper that hit a curb. The term you are refering to is called "Braking metal" or a metal brake.
    Actually the term is BENDING or FORMING metal in a PRESS brake...
  12. #12
    snakebit95 is offline Aluminum
    Dec 2005
    Montgomery, AL
    239
    Post
    I found this a few months ago, when I was looking for the same thing. I am thinking about building my own. Pretty handy thing to have around the shop.......that's for sure!!
    http://www.shopoutfitters.com/HandyBender.html
  13. #13
    wlbrown is offline Hot Rolled
    Nov 2002
    wright city, mo.
    582
    Post
    HELLO TO ALL,
    for heavy material, you must increase the
    radius.(larger male die) this also presents
    problems with setback. i am sure there are
    tables somewhere on the internet that tells
    how. or you can do it trial, and error.
    good luck with your projects.
    wlbrown
    wright city, mo.
  14. #14
    jjclear is offline Plastic
    Dec 2006
    South Jersey
    44
    Post
    I made this up a couple of years ago. It works real well for 1/4" plate. I needed to make up some brackets for a car I'm building and needed a way to bend accurately. I used a stick on measuring tape and pointer to be able repeat bends. Sorry about the rust.
    J. Clear
  15. #15
    pm
    pm is offline Senior Member
    Feb 2006
    jersey city baby!
    134
    Post
    jjclear - that's nice!
    did you make that male die holder from a solid billet or is it repurposed from something else?
  16. #16
    kilroyjones is offline Hot Rolled
    May 2005
    South Central Kansas
    578
    Post
    You will also need to adjust the size of the V on the bottom dies for varying material thickness.
    A simple formula is material thickness x 8 equals the distance across the top of the V.
    For .125" material the distance from one top edge of the V to the opposite top edge is 1". For material over a 1/4" thick you need to use x10 instead of 8.
  17. #17
    Dec 2006
    South Jersey
    44
    Post
    pm,
    That was just a hunk I had laying around. I milled a 1/2" slot into it in the hopes of some day picking up some real dies.
    kilroy,
    Thanks for that tip. I haven't done a whole lot of metal bending. Not on purpose anyway. <G>
    J. Clear
  18. #18
    flathead4 is offline Hot Rolled
    Sep 2006
    Spotsylvania, VA
    656
    Post
    J. Clear,
    I see from your photos that you use Pampers brand storage containers. [img]smile.gif[/img] I've got some of those, too.
    Tom
  19. #19
    johnoder's Avatar
    johnoder is online now Diamond
    Jul 2004
    Houston, TX USA
    16,476
    Post
    You can also do forms.
    I burnt out some 1 3/4 plate curves, male and female, and they did instant forming of 10 ga sheet in my 25 ton
    John
  20. #20
    hrhoades is offline Cast Iron
    Nov 2002
    Milton,WI USA
    310
    Post
    Here are some photos of how I built mine so I could use in place of a pan brake.
    Hal
    IMG]http://img.photobucket.com/albums/v36/hrhoades/press%20brake/pressbreak006.jpg[/IMG]
