raff35, that 13" is the baby brother to my 17". There is only one motor and no Servo-shift, just good old honest, broad range, hand-shift gearing. The Servo-shift came in with the 'Modern', chunky square look.
The impressive looking 'selector' on the headstock is nothing but a speed/feed advisor. It has no links to anything but the operators hand/brain/eye. I find it quite useful, now that I've gotten over the disappointment of it only being an animated speed chart that is soil resistant.
The several of this family that I've gotten close to, typically show the scars of students but no great wear damage.
Some salient facts; the bearings are all of the 'frictionless' type, IE, needle, ball or roller, that's good. The gears are high quality. The threading range is quite good.
I love mine, I find it to be a lot more hardy, versatile and competent than I expected from a teaching tool, at which it excells and should be perfect for your level of experience and ideally sized for your stated needs.
Grab a moderate trailer and go get that thing with your Isuzu! I advise bringing a couple of light timbers, I used 10' 4X8's for my 17", drilling bolt-down holes, counterboring for the bolt heads, for the legs at each end. The timbers provide positive locators for securing the legs during transport and make unloading and manuvering into it's final resting place, rolling on pipes, an easy job.
WARNING! Lathes are easier to teach to roll-over than a dog is. I successfully moved mine single handed. It was placed on my trailer with a forklift. I then 'tied-off' one side by attaching a come-along, high, on each end of the lathe and to the rails of the trailer, attaching a third on the opposite side and cranking the first two taut with the third.
Then I incrementally released the first 2 as I took up the slack with the third, safely tipping it until there was enough room to slip the first timber, bolts sticking up, under the raised legs on the back, (heavier) side, bolting them solid. Duplicated this for the operators side. Screwed blocks to trailer bed to lock timbers in place. I then secured the lathe with 4 come-alongs, chain binders and rope, yeah, over kill. Bring something like small wooden blocks and grain bags to protect the lathe from any chain or like.
At my shop, I backed the trailer up to the door, attached a come-along, front rail to lathe, heavy slack (anti-roll) ropes on both sides, elevated the trailer tongue, back frame onto concrete, with a tall jack. Then with a bottle jack under the leg cross bars, I raised each end of the lathe to place 1" pipe rollers under timbers. Backing off the come-along and adjusting the side ropes, eased the lathe down onto my shop floor.
The move was a non-event.
...yer gonna' love it!
Bob
I got called away before posting this and others filled in most of the info. I decided not to edit but to confirm what the others had already said.
