Best hand truck for 650lb load, lean back wheels?
Results 1 to 6 of 6
    Jan 2005
    Williamsville, NY
    576
    6
    8
    Post
    I did a search and nothing came up. I am looking to move a safe with a handtruck. I am looking for the same type the gentleman who delivered the safe used.
    The safe weighs 650 pounds. I would like this handtruck to have 4 wheels-2 primary, and 2 behind like a kickstand so I can push this safe around with out having to balance it.
    Generally, this is referred to as an "appliance hand truck" and/or "vending machine handtruck".
    What gets me is in home depot they have a cheap $99 version of such a thing with no bearings in the wheels, a really really really crude strap anchoring system with no ratcheting action, and it is made by "Milwaukee".
    Possibly the SAME EXACT model, also made by "Milwaukee" is going for twice as much. Now, in home depot, I expect crap, and the level of quality on this hand truck was crap.But on the internet, it is very hard to inspect the details on such an item.
    What bothers me is there are not GOOD PHOTOS posted on vendor's websites so I can see what I am getting.
    Anybody with a really good one they would recommend or know of a really good dealer in Southern California? Thanks in advance!!
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,670
    2400
    5259
    Post
    Below is copied from McMaster Carr. They list wheel bearing types and the cheapest with ball bearing wheels is about $235. The better ones with 1,200 lb capacity and the lean over retractable leg is aprox $370. These have roller bearing wheels.
    Northen Tool sells these too, so perhaps there is a Northern store near you and you could inspect in person.
    For $1,600 you can get one with motorized wheels for power stair climbing !
    Cap., Load Plate, O'all Size, Wheel Size, Wheel Strap Frame
    Style lbs. Wd. x Dp. Wd. x Ht. Wheel Type Dia. x Wd. Bearings Tightener Gauge Each
    Two-Wheel Trucks— Steel
    A 750 24" x 5" 24" x 60" Cushion Rubber 6" x 2" Plain Hand Crank 14 2598T81 $204.70
    A 750 24" x 5" 24" x 60" Cushion Rubber 6" x 2" Plain Ratchet‡ 14 2598T82 245.00
    A 800 24" x 5" 24" x 60" Solid Rubber 8" x 2 1/2" Ball Hand Crank 14 2598T91 233.77
    A 800 24" x 5" 24" x 60" Solid Rubber 8" x 2 1/2" Ball Ratchet‡ 14 2598T92 265.57
    Two-Wheel Trucks— Aluminum
    A 500 24" x 4 1/2" 24" x 47" Cushion Rubber 5" x 2" Roller Ratchet ___ 2871T31 268.22
    A 500 24" x 4 1/2" 24" x 59" Cushion Rubber 5" x 2" Roller Ratchet ___ 2871T32 297.03
    A 500 24" x 4 1/2" 24" x 59" Cushion Rubber 5" x 2" Roller Ratchet ___ 2871T33* 324.74
    Four-Wheel Truck— Steel
    B 750 24" x 5" 24" x 66" Cushion Rubber 6" x 2" Plain Buckle 14 2598T71* 235.60
    Four-Wheel Truck— Aluminum
    B 500 24" x 4 1/2" 24" x 71" Cushion Rubber 5" x 2" Roller Ratchet ___ 2871T34* 357.99
    Four-Wheel Trucks with Retractable Leg— Steel
    C 1200 24" x 5" 24" x 60" Thermoplastic 8" x 2" Roller Ratchet‡ 14 2654T4 371.00
    C 1200 24" x 5" 24" x 66" Thermoplastic 8" x 2" Roller Ratchet‡ 14 2654T5 377.00
    C 1200 24" x 5" 24" x 72" Thermoplastic 8" x 2" Roller Ratchet‡ 14 2654T6 383.00
    ‡Includes an automatic strap recoil mechanism.*Furnished with two web straps.
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1001
    Post
    I have a "Dayton" (Grrrainger) without the rear "brace" wheels. It's aluminum with the ratchet strap and it's soooo nice. I paid a premium for those features but the truck is lightweight and can be carried around without breaking a sweat. I justified the cost of this on our last move where we got paid a flat amount to get the job done and did it ourselves to get the savings over a hired move, with rented trucks and that "little helper". [img]smile.gif[/img]
    Apr 2005
    Benton, IL USA
    4,567
    7
    43
    Post
    Take a look at Model 6873-49 from Harper Trucks.
    100% made in the USA (Wichita, Kansas). Available at Airgas & other local welding supply stores. I have two of their welding cylinder trucks, both are built like a brick house.
    Barry Milton
    May 2003
    San Diego
    38
    Post
    We used these to move video games when i was in that field. They are very nice.
    You can usually rent them from your local rental place for $10-$15/day if you just need to move that safe once or twice.
    Feb 2005
    Chapel Hill, NC, 27516
    308
    Post
    When I needed one I looked at all offerings I could find from Web search and catalogs and settled on Lift Rite from Grainger. They have steel wheels, rather than plastic and are well-constructed. I have been completely satisfied with the two I bought, one narrow & low profile and one extra heavy duty. The Lift Rite is the only brand I would recommend for serious use where dependability and long life is desired.
    Lift Rite pallet trucks from Grainger:
    http://www.grainger.com/Grainger/wwg...mId=1611777769
    Heavy Duty Hand Truck Pallet, Load Capacity 8000 Pounds, Overall Length 61 3/4 Inches, Lowered Fork Height 3 1/4 Inches, Raised Fork Height 8 Inches, Fork Length 48 Inches, Fork Width 7 Inches, Width Across Forks 27 Inches
    http://www.grainger.com/Grainger/wwg...mId=1613405306
    Hand Pallet Truck, Load Capacity 5500 Pounds, Lowered Fork Height 3 Inches, Raised Fork Height 7 3/4 Inches, Fork Length 48 Inches, Fork Width 7 Inches, Overall Length 61 3/4 Inches, Width Across Forks 27 Inches
    http://www.grainger.com/Grainger/wwg...mId=1611777766
    Narrow Hand Truck Pallet, Load Capacity 5500 Pounds, Overall Length 61 3/4 Inches, Lowered Fork Height 3 Inches, Raised Fork Height 7 3/4 Inches, Fork Length 48 Inches, Fork Width 7 Inches, Width Across Forks 20 1/2 Inches
    http://www.grainger.com/Grainger/wwg...mId=1611777768
    Low Profile Hand Truck Pallet, Load Capacity 5000 Pounds, Overall Length 61 3/4 Inches, Lowered Fork Height 2 Inches, Raised Fork Height 6 3/4 Inches, Fork Length 48 Inches, Fork Width 6 Inches, Width Across Forks 27 Inches
    http://www.grainger.com/Grainger/wwg...mId=1611777772
    Ultra Low Hand Truck Pallet, Load Capacity 5000 Pounds, Overall Length 61 3/4 Inches, Lowered Fork Height 1 3/4 Inches, Raised Fork Height 6 1/2 Inches, Fork Length 48 Inches, Fork Width 6 Inches, Width Across Forks 33 Inches, Four Way Entry
