Can you bend copper tubing with a pipe bender?
Results 1 to 13 of 13
    Feb 2005
    Birmingham, AL
    4,025
    13
    40
    Post
    I have some copper tubing 3/4" that I want to bend. I have a Greenlee model 1800 conduit/pipe bender. Im thinking the 1/2" pipe groove on the bender and 3/4" tubing is about the same size, so might work. Anybody know about this situation?
    Feb 2005
    Akron, Ohio
    723
    281
    101
    Post
    Hello,
    Unless it is soft or annealed copper tubing you will have no luck bending. The tubing will buckel and collapse. Type L & K straight length water line won't work.
    Brian
    Nov 2005
    Maryland
    8,508
    741
    1059
    Post
    No. That's why they sell elbows (pre-fab bends).
    Feb 2005
    Birmingham, AL
    4,025
    13
    40
    Post
    Im talking about tubing here, not copper pipe. elbows are for pipe. I know copper tubing can be bent (It comes in a roll) but can it be bent with a conduit/pipe bender, since I dont have a 3/4" tubing bender laying around.
    Sep 2004
    FL
    164
    17
    Post
    A thinwall electrical bender works well for this. I have used it many times for a neater looking bend on soft copper AC lines rather than freeform hand bending.You need to lay the tubing on a hard floor and bend with downward pressure of your foot. Pulling the tube around with your hand will kink it. Hard copper can also be bent but you have to aneal it first. I use enough heat to darken the tube a bit beyound the bend.You can use a red heat but a thick oxide scale will form.For AC work a nitrogen purge will prevent the scale from forming on the inside.Plan to make a few practice bends.Some flatening of the tube is inevitable.
    Oct 2005
    tulsa,okla
    791
    7
    Post
    yes, it can be bent. i had to do this a couple years ago and needed a special bend in copper tubing. tried bending on a conduit bender and although technically it bent, it was flattened out more than i cared for in the middle of the bend.sooo... i then cut a longer than neccassary piece of tubing and filled it with sand(fine ashtray sand is better b/c large grain sand will dent the tubing-if appearance is an issue)cap one end with a cap and solder on. fill slowly and keep tapping on bench or floor to make sand settle till it won't settle anymore and then solder on another cap. make your bend and cut off the ends to remove sand. this way the bends can usually be made by hand or the bender.
    Feb 2005
    Birmingham, AL
    4,025
    13
    40
    Post
    This will be the discharge for an air compressor Im plumbing. A little flattening would be OK. A near collapse not ok.
    Aug 2005
    Tacoma Washington
    1,334
    82
    123
    Post
    I work with type K copper all the time. When I want to bend it, I just grab onto it and bend it around my leg. Cut it a little long for leverage, make your bend, and then trim to sute. If you need to re-anneal, just heat with a propane torch (OA will work too) and let it cool slowly.
    Aug 2004
    Kingston, WA
    207
    Post
    I'm a little surprised to hear that I can't bend hard copper tubing ("pipe") with my bender, especially since I've done it many times. I can bend 1/2" copper pipe in my JD2 bender using a 5/8" die. I've done bends from a few degrees, up to > 90 degrees. The copper pipe does not collapse. It bends very nicely, actually; just like DOM but with much less effort.
    - Glenn M.
    Jan 2005
    CANADA
    Saskatchewan
    9,432
    1138
    3175
    Post
    Well Glenn, now you know. Tomorrow you've got to go out and find a new way to do it
  11. #11
    Aug 2004
    Kingston, WA
    207
    Post
    Well, Flung Dung (or should that be "Dung Well Flung"?) I guess you are right.
    Thinking about this, I wonder if there might be some confusion about what exactly is meant by a "bender." A conduit bender might collapse Cu pipe; I don't know about that. Never tried it. But a "real" tubing bender has a die and a shoe that support the tubing during bending.
    I've successfully bent .049" wall 6061-T6 tubing in that die. That seems more likely to collapse than Cu pipe, but it wasn't a problem. There is very little flattening on the bend.
    I've done the sand-bending routine for other jobs, too, but there is no need to pack the tubing if you are using type K copper. I haven't tried type L, but I imagine it would probably be OK, though type L is not recommended for compressed air according to the "Copper Development Organization."
    There is lots of good info on working with copper pipe for compressed air and industrial applications here: copper tech ref
    -Glenn
  12. #12
    Mar 2002
    Ramona, Ca. USA
    1,377
    Post
    Ever used this stuff? I have seen it used for tube bending when the real tooling was not avalible.
    http://en.wikipedia.org/wiki/Cerrobend
  13. #13
    Jul 2007
    Queen Creek, AZ
    7
    All,
    I know this is an old thread, but since it was what I found during a search, I thought I'd add a data point (BTW, I understand also that the original poster wanted to know if soft copper tube could be bent with conduit tooling, but the discussion morphed toward forming hard copper L and M pipe, which was my issue...):
    This afternoon, I attempted to use my Pro Tools 105 tube bender with a 7/8" x 3.5" radius die to bend both L and M 3/4" pipe (7/8" O.D.). Three attempts, three failures....The first attempt with the L pipe was the closest to a success, but there was a significant amount of wrinkling on the inside of the bend. The second attempt with the L pipe actually broke the pipe after 40 degrees of bend. The only attempt with the M pipe broke the pipe with less than 20 degrees of bend completed!
    I appreciate the tips you guys posted in this thread; there are other options for me to try. I just wanted to share my experience with this process using what might be common tools and materials for others.
    Jon
