Can you convert a Natural Gas Furnace to Propane?
Results 1 to 10 of 10
    Jul 2004
    Troy, NY, USA
    969
    Post
    I was offered natural gas forced air furnace for free. The problem is that where the furnace would be installed, natural gas is not availible from the utility company, so the only source of fuel would be propane. What's involved in converting these units? Anyone done it, or converted from propane to NG? Thanks.
    Nick
    Apr 2002
    Syracuse, NY USA
    9,587
    16
    537
    Post
    generally yes. I built a house long time ago where there was no ng, but I figured there would be, so I put in a lp furnace and it was converted a few years later when ng arrived. generally just an orifice needs to be replaced, like a 2 dollar part.
    Dec 2005
    Kalispell, Montana
    1,257
    10
    Post
    GO to your local propane dealer with make and model of your furnace. All that is required is to change an orfice in the gas valve, like changing jets in carburetor. If you can get the right orfice, no problem at all.
    jim
    Feb 2005
    Honcut, Ca. USA
    970
    Post
    Sometimes the conversion is built into the gas valve. My new furnace just required removing a plug, reversing it, and screwing it back in.
    That, and tightening the orifice a couple of turns.
    You would defintely want the owner's manual for your model, though.
    Dec 2005
    BC Canada
    162
    Post
    Like everyone else has said, YES it relativley easy to do. Usualy NG appliances run about .5 to 2 psi (although there are a few higer pressure systems out there) while propane is about ~30 psi.
    I converted one a few years back, in that case I hade to enlarge the jet. I just did some research on the the BTU's of each fuel, and the the BTU rating of diff sized jets, and then did some math to get the required jet size, and simply drilled it out to the new size. Depending on the model etc, you may also need to change the pilot flame jet as well.
    This is a very std conversion, and most gas fitters would be able to do it quickly, if you dont want to tackle it yourself.
    Tim
    Sep 2001
    Midland, Michigan
    668
    Post
    Some conversions require a complete new control valve plus orifices. In my case the Honeywell valve to use NG was $121.00 and I drilled out the orifices to the larger diameter required. The old (but never used) two stage LP control valve sets on the shelf.
    May 2003
    Iowa
    10,065
    3191
    3866
    Post
    I had a furnace converted 3 years ago. Most of the newer units will require a different control valve and jets. If it's got electronic ignition, you should add a standing pilot light for safety.
    In either case, have a heating contractor do it. Every year I see something about a house blowing up and it's usually because somebody was screwing around with a propane furnace.
    JR
    Jan 2005
    CANADA
    Saskatchewan
    9,434
    1138
    3175
    Post
    No, no I can't. Thank you for asking though. Your inquiry was important to me.
    Oct 2005
    Ont. Canada
    659
    Post
    When you purchase a new unit, Like Armstrong,
    it comes with NG installed plus a conversion kit
    for LPG. The manufacture, or outlet, can only
    sell through an authorized & licenced dealer
    ( contractor ), and is to be installed by the
    same. Which means if you're not licenced, you
    can't purchase and install yourself. When the
    installer installs your furnace, he must remove
    all parts not used. You can't keep them.
    I tried to get them to change their minds but
    they won't budge on it.
    Jul 2004
    Troy, NY, USA
    969
    Post
    Thanks for all the replies. Next step is to get a quote from a local contractor.
    Nick
