New member here. I need to make 4 studs,1/2" dia. and 6 1/2" long, threaded on both end 20 tpi. They should have the strength of a grade 5 bolt or better. These studs will replace the bolts that hold the main bearing caps to the block on a Model A Ford engine with about 50 HP and a torque of 80 fp on the studs. I have some drill rod W1, will that work or should I use something else? I will thread them in a lathe but did not plan to send them out for heat treating. Your advice will be appreciated. Thanks Nick
