Can you cut pipe threads on a lathe?
Results 1 to 17 of 17
    Jan 2006
    Angier, North Carolina
    2,223
    678
    696
    Post
    This may be a dumb question, but I've never seen it addressed --
    I know that pipe threads are tapered. Could a person cut those threads on a lathe equipped with a taper attachment set to the appropriate taper?
    Oct 2002
    ohio usa
    111
    Post
    YES, They can. It's sometimes easier to rough chase straight & run a die on though.
    Nov 2003
    Colorado
    3,211
    1967
    3841
    Post
    Here's a boiler wash out plug being made without a taper attachment between offset centers:
    Jun 2001
    WI
    656
    6
    Post
    Yes. I tried it today on a SBL with taper attachment.
    Mar 2005
    Kansas
    6,563
    334
    2719
    Post
    I've done tapered threads by the ways listed above. The fastest way I have ever found on a manual lathe to chase them is with a tracer. That only works if you need to do a couple of dozen or more.
    The usual way I do them is to turn the tool upside down, and thread away from the chuck. Then I just turn the compound in as I feed off the part after I get the whole thread to the big end size. Do the math as to how much to feed in each revolution. With a little practice as to how fast to feed in, and you can pass a thread gage test.
    May 2004
    Amherst, Nova Scotia , Canada
    617
    Post
    The way I was shown, although dont know how many do it this way becuase there are faster ways, i guess, is to machine the taper(I believe its 1 degree and 47'?)then set your tool bit square with the diameter,NOT the taper you just cut...then thread away..
    Jan 2003
    Canada
    10,683
    4462
    2855
    Post
    On a lathe that doesn't have too much backlash and with some practice its possible to freehand the taper if the lathe doesn't have a taper attachment. Just cut the ouside taper with the compound first to have something to follow. It doesn't make a thread as accurate as if cut with a taper attachment. But sometimes it does the job if the pipe isn't running much pressure and that theres no chance for it to kill someone if it leaks. You can always chase it with a die after to fine tune it.
    At first I thought it was a crazy idea to freehand a pipe thread but after doing a couple I was quite pleased with the results. Although I wouldn't do it on anything critical or anything that was being sold to a customer. I'm just mentioning it because some guys just can't spend $1000 on a taper attachment to cut a thread for some widget they're making for the backyard.
    May 2004
    617
    Post
    does anyone do it the way I mentioned or am i way out in left field?
    Jan 2002
    home
    1,025
    Post
    I do it just like gbent posted , its fast and works fine for pipe.
    Jan 2003
    Canada
    10,683
    4462
    2855
    Post
    CatHead, always set your tool square with the part. It's the way its supposed to be done. Never set the tool to the taper. So you're doing it right.
  11. #11
    Jun 2001
    St Louis
    16,501
    1327
    2456
    Post
    That deal of setting square to the part is also how I was taught, and makes sense.
    It is also a really good argument for using a taper attachment.... You are setting square to the CENTERLINE of the part, which is actually at an angle if you are taper turning by offsetting T/S. Makes it hard to set to.
  12. #12
    May 2005
    JAPAN
    1,225
    9
    Post
    That's correct, don't set to the taper.
  13. #13
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    175
    Post
    Also I read somehwere that for may pipe sizes it it acceptible to use a tapered female with a straight male thread, machineries handbook maybe ??
    Parts would not be to print so it would only be for parts you are making for your own use. I have used 1/8 NPS nipples before in a pinch and they worked fine with some teflon tape on them..that was before I read the information.
    Bill
  14. #14
    Jan 2006
    2,223
    678
    696
    Post
    I've got the taper attachment, assuming I ever get my lathe put back together! [img]smile.gif[/img]
    Do you taper the piece before threading, or just taper the threads themselves? And how much taper? Somewhere I think I read 1/4" per foot -- is that right, or did I dream that somewhere?
  15. #15
    Dec 2004
    Falls Church, VA
    1,225
    Post
    With regard to mixing straight and tapered threads, the following may be helpful:
    "Pressure tight joints for low pressure servce are sometimes made with straight internal threads and the Americian Standard taper external threads. The ductility of the coupling enables the straight threads to conform to the taper of the pipe thread. In commercial practice straight-tapped couplings are furnished for standard-weight (Schedule 40) pipe sizes 2" and smaller."
    pg 7-150, Piping Handbook, 5 ed, McGraw Hill. Chapter 7 was written by Helmult Theilsch, manager of the Research and Development Division, Grinell Corp, and one of the recognized authorities on piping. In many ways the 5th edition of this handbook is better than the 6th edition.
    Oh, Yes, the taper is 3/4 inch per foot.
    Thermo1
  16. #16
    Jul 2005
    NE Ohio
    517
    Post
    You dont have to taper the work piece before threading. The threads will be tapered
  17. #17
    May 2002
    Auckland, New Zealand
    4,340
    1149
    386
    Post
    Is it possible to do this properly by off-setting the tailstock? I am worried about that boiler washout plug now ... Not something to get "roughly right".
